Calculate Value of Resistor R in Ex31.21 | ΔV = 5.0V, I = 62mA
  • Thread starter Thread starter Phoenixtears
    Resistor Value
The discussion revolves around calculating the value of a resistor R in a circuit, specifically in the context of a problem where the voltage (ΔV) is given as 5.0 V and the current (I) is 62 mA. The participants are exploring the application of Ohm's law in this scenario.
  • Participants discuss the use of the equation RI=V and the implications of total resistance in a circuit. There are attempts to clarify the necessity of considering other resistances in the circuit setup.
Some participants have provided guidance regarding the importance of accounting for additional resistances in the circuit, while others express a desire to understand the underlying concepts rather than simply applying formulas. The discussion reflects a mix of attempts to clarify the problem and explore the reasoning behind the calculations.
There is mention of specific resistances (10Ω and 15Ω) that may need to be subtracted from the total resistance, indicating that the problem may involve a more complex circuit configuration than initially presented.
Phoenixtears
SOLVED
What is the value of resistor R in Figure Ex31.21, in which ΔV = 5.0 V and I = 62 mA?
(Image Attached)
RI=V
My attempt at the solution is literally solely the equation above. I can't see any other way to angle it. I've done it a few different ways (all using the above equation) and keep getting the answer 80.6. Can anyone help me on this one?
Thanks in advance!
~Phoenix
Phoenixtears said:
RI=V
Hi Phoenix! :wink:
erm :redface: … did you remember to subtract the 10Ω and the 15Ω? :smile:
R = V / I = 5 / 0.062 gives you the total resistance
*Sigh* Thank you so much, both of you! Figures I'd forget something so simple.
Now I'll never forget that... hopefully.
Thank you!
Thank you!
Physics is not about remembering ''tricks'' for certain situations. You can forget this solution, but what you should have learned from this is that it's important to analyze the problem. Understanding the problem is half the solution. If you would have asked yourself ''what resistance is it I'm calculating if I plug V and I into Ohm's law?'', then you would've been able to solve the problem yourself!
Actually, this is the first time I've really used resistance in this manner at all. I didn't know about a 'total resistance' and the fact that each small section holds a separate resistance that adds up to the total resistance. And I'm not in physics to remember tricks. I want to understand the material. My comment about not forgetting had nothing to do with the solution, but about the idea of total resistance.
Thanks for helping me, but please don't assume that I'm only in physics to pass.
That's very well then!
I didn't assume you only do physics to pass. I assumed you knew about multiple (serial) resistances would add up to a total resistance and tried to remember all the ''tricks'' to solve questions regarding resistance. That appears not to be the case, no big deal then.
You're welcome.
  • · Replies 60 ·
10K
  • · Replies 16 ·
