Vapor pressure and atmospheric pressure
The discussion revolves around the relationship between vapor pressure and atmospheric pressure, particularly in the context of boiling points at different altitudes. Participants explore the definitions and implications of vapor pressure, mechanical equilibrium, and how atmospheric pressure influences boiling points without affecting vapor pressure directly.
  • Some participants assert that vapor pressure is independent of atmospheric pressure, yet it must equal atmospheric pressure for boiling to occur.
  • One participant describes a mechanical equilibrium perspective, suggesting that vapor can only form if its pressure is equal to or higher than the pressure of the air above it.
  • Another participant expresses confusion regarding the relationship between atmospheric pressure and boiling points, referencing a problem from their book that states vapor pressure depends solely on temperature and solute concentration.
  • It is noted that at higher altitudes, lower atmospheric pressure results in a lower boiling point, as less energy is required for the vapor pressure to equal the reduced atmospheric pressure.
  • One participant clarifies that while atmospheric pressure does not affect vapor pressure, it does influence the temperature at which boiling occurs.
Participants generally agree that vapor pressure is defined independently of atmospheric pressure, but there is contention regarding how atmospheric pressure influences boiling points and the conditions under which vapor pressure and atmospheric pressure must equalize.
Participants reference definitions and concepts that may depend on specific interpretations of vapor pressure and mechanical equilibrium, which could lead to varying conclusions based on different assumptions.
silversurf
the book says vapor pressure is independent of atmospheric pressure, if that is the case then why must the vapor pressure of a liquid be equal to the atmopheric pressure for it boils. I pictured atmospheric pressure as a column of air sitting above a liquid and therefore pushing down the gas molecules from the liquid ,thus affecting its vapor pressure
Chemistry news on Phys.org
When you consider a column of air sitting above a piston below which there is the water, then the vapour can only form if its pressure is equal or higher than the pressure of the air. If it is smaller, the vapour molecules will be pressed back into the liquid. This does not mean that the vacuum pressure changes appreciably with external pressure. It is rather a statement about mechanical equilibrium.
Vapor pressure, not 'vacuum pressure', whatever that is.
The last sentence is where I'm getting confused. There was a problem in my book that said that you have a pot of boiling water at sea level and boil it. Then you take that same pot of water to mount everest and boil it, and the boiling point it lower at higher altitude. Due to higher altitude the atmospheric pressure is lower. I saw this as the atmospheric pressure exerting less force on vapor pressure so you would need less energy/temperature to get the water to boiling point, where atmospheric pressure = vapor pressure. So my reasoning is, less atmospheric pressure = less vapor pressure = lower boiling point. But there's a problem in my book that says that vapor pressure only depends on temperature and particles dissolved in solution. I understand that temperature and vant hoff factor affect vapor pressure but why doesn't atmospheric pressure affect it too?
vapor pressure of a liquid is the pressure at which vapors of the liquid are saturated. if you increase that pressure by just one tad bit by introducing additional vapors into the fixed volume, the molecules will be so close together that you will have a liquid instead of a gas.
so , :) a liquid will boil when the pressure exerted by its vapors (vapor pressure) equals the atmospheric pressure. this simply means that when you have an equal amount of molecules of that liquid escape and exist in the gas phase as there are molecules of air, we observe boiling.
so, at sea level, you have more molecules of air in a fixed volume (higher pressure) then you do high up on a tall mountain. this means that high up on the mountain the liquid we are trying to boil will need to have a fewer number of its molecules escape in the gas phase than it did at sea level in order to equal the number of molecules of air in a fixed volume. hence you will observe boiling at a lower temperature.
so as you can see the atmospheric pressure does not affect the vapor pressure (see definition at top of my post) but it affects the temperature of the boiling point
Got it, thanks so much!
  • · Replies 31 ·
  • · Replies 26 ·
  • · Replies 0 ·
