Variable AC (0 to 240) source how to take fixed DC (110 or 220)
This discussion focuses on converting a variable AC source (0 to 220V) into fixed DC outputs of 110VDC and 220VDC. Users recommend employing a rectifier bridge to convert AC to DC, while emphasizing the importance of using an isolation transformer for safety and to prevent issues with DC premagnetization current. The use of a Variac, or adjustable transformer, is suggested for voltage adjustment, but caution is advised against using standard lamp dimmers due to safety concerns. The consensus is to either purchase dedicated DC power supplies or utilize an isolation transformer in conjunction with a Variac for effective and safe operation.
  • Understanding of rectifier circuits for AC to DC conversion
  • Knowledge of isolation transformers and their safety applications
  • Familiarity with Variac (adjustable transformer) operation
  • Basic electrical safety practices when working with high voltage DC
  • Research the specifications and operation of rectifier bridges for AC to DC conversion
  • Learn about the design and application of isolation transformers in power circuits
  • Explore the functionality and safety considerations of using Variacs in electrical systems
  • Investigate commercially available DC power supplies suitable for testing components
Electrical engineers, hobbyists working with power electronics, and anyone involved in testing electronic components requiring stable DC voltages.
rajeshputta
sir,
i am looking for fixed DC (110VDC and 220VDC) from my variable AC source (0 to 220V).
please support me.
rajesh.p
9010770003.
Buy separate fixed DC output sources.
How much power? How about some real specifications, and some ideas you might have had. What are you really trying to do. Some context makes it easier to come up with ideas.
At first glance, it seems difficult to get 110VDC from 0V AC, but I might be missing something.
Why do you expect us to do more work than you are willing to do. I already spent more time on it than you spent posting your question.
thank you for your support on my topic,
equipment input supply 240V,50Hz,1ph, output 0 to 220VAC is variable dimmer source available, using this source i want produce fixed type at out put section 110,220VDC &3 to 5Amp.
here we have used rectifier bridge for make convert of AC to DC source,
i looking here need 110V and 220V dc it is for our safety to test the components those DC levels only.
(while i testing time i struggle to set the desire voltage, some times this variable nob get increase or decrees is happens, due to i facing failure our components at testing time)
i expecting any circuit is available for desire voltages select?
if available please help me.
rajesh.p
I've seen people put an isolation transformer after a variac and simply rectify and filter. Be sure to use fuses that are rated for HV DC. Common AC fuses arc badly when attempting to break DC.
Actually, Bystander nailed it. Buy two DC power supplies and switch between them. Are you trying to do something that won't provide?
The main reason they use isolation transformer is probably to eliminate/reduce potential problems with DC premagnetization current.
The isolation transformer is for safety. Given that an AC neutral ties back to ground, There's no means of attaching the rectified + or - DC to ground without either fireworks, or an isolation transformer. Folks who design offline power equipment regularly keep the transformer / variac combination upstream. I used to keep a 10 kW pair upstream with a breaker bar on the variac because my wrists and forearms weren't up to turning the dial.
Function is to "serve" and to "protect". Protection role/safety increase of isolation transforners is obvious, as already explained here. I was referring to their advantage in service with rectifier circuit topologies.
Is that what you are using? or are you asking if one is available?
A Variac, also known as "Adjustable transformer" or "slider" , will work well for you with a rectifier
but an everyday household lamp dimmer will not..
I agree with others - you should buy an isolated power supply or use an isolation transformer.
Variac doesn't isolate the neutral wire and folks get into trouble using one with a bridge . In a US system, earthing either side of the DC bypasses half the bridge.. making sparks and smoke.
  • · Replies 23 ·
  • · Replies 22 ·
