Fluctuating Refractive Index and Light Perception
The discussion centers on how a narrow beam of light passing obliquely through a slab with a fluctuating refractive index affects light perception. The initial analysis involves calculating the image position based on the slab's thickness and refractive index. However, there is confusion regarding the interpretation of the problem, as it specifies an oblique beam rather than a perpendicular view. The differentiation of the image position concerning time raises questions about the physical implications of changing refractive indices. Overall, the focus is on understanding the effects of a dynamic refractive index on light perception through an oblique passage.
utkarshakash
A narrow beam of light passes through a slab obliquely and is then received by an eye. The index of refraction of the material in the slab fluctuates slowly with time. How will it appear to the eye?
Let a point object be kept at a distance u to the left of the slab. Now I can find the final position of the image and it comes out to be (t/μ + 1) where t and μ are thickness and refractive index of the slab.
Differentiating this wrt time
dv/dt = c (dμ/dt)
How to interpret this physically?
I'm not sure you are addressing the given problem. It says an oblique beam of light, not an object viewed perpendicularly through the slab. So I don't think distances come into it (but that might have been a more interesting question).
  • · Replies 24 ·
