Variation statement into graphs- Right?
  • Thread starter Thread starter xNick94
    Graphs Variation
The discussion revolves around interpreting the formula F = kQq/R² and sketching graphs based on the relationships between the variables. It confirms that F is directly proportional to Q, indicating a direct variation graph. For the relationship between F and R, participants clarify that F is inversely proportional to R², which leads to confusion about graphing it correctly. The conversation also touches on expressing relationships, such as whether to express R in terms of Q or vice versa, and emphasizes the importance of understanding the nature of these variations. Overall, the participants seek clarity on how to accurately represent these mathematical relationships graphically.
xNick94
My first post, yay i already like the atmosphere here :P anyway...
Using the formula F = kQq/R2 sketch graphs between
a. F and Q (k,q, and R are constant)
b. F and R (Q,q and k are constant)
c. Q and R (k,q and F are constant)
I think i did it correctly but I'm not quite sure.
a) I wrote that F is directly proportional to Q so i guess its Direct Variation graph.
b) Is 1 / R^2 inversely proportional? And is the graph the same as y= 1/x or should it be y=SQUAREROOT of 1/x but then it wouldn't make sense?
c) i got it so that it's R = SQUAREROOT of Q so it's direct root graph?
I hope that's correct! Can anybody double check?
Your (a) sounds good
In (b) you said it was 1 / R^2, then immediately inversely proportional. What happened to the square?
(c) is a true statement, but why express R in terms of Q, when the question said Q in terms of R ?
Thanks for your reply,
I suspected it could be Square.root 1/R.
and does it really make a difference if you express it in the other way?
I have not seen many people claim the radius of a circle varies as the square root of the Area when asked to draw a graph showing the relationship between the Area and radius of a circle.
The test of whether it makes any difference would be when you change the variables you graph to get a straight line so that you can determine the complete relationship.
And I don't think the second one is Square.root 1/R. The way you are writing them, it could be Square.root 1/F
I'm really confused :( I'm trying to understand it but I'm having trouble grasping the concept - F is proportional to R^2 since the R^2 came from F=kQq/R^2. So why doesn't that make it an inversely proportional graph or what is it even supposed to be- this is really frustrating :(
F is proportional to 1 / R^2 - but I think you just mis-wrote it.
if you were to graph y = 1/x you would get a graph showing inverse proportion.
But there is also y = 1/x^2 - the inverse square, y = 1/x^3 , the inverse cube etc.
Alright that makes sense, thanks for all your help!
  • · Replies 42 ·
  • · Replies 23 ·
