Vec norm in polar coordinates differs from norm in Cartesian coordinates
47 replies · 9K views · last reply
Orodruin said:
there is really no need to make a distinction between the vector space of translations and the tangent spaces at each point
I disagree. You can get away with this in flat spaces, but not in curved spaces. Since we are in the special and general relativity forum we often deal with curved spacetime here. So I would recommend making the distinction here.
I think, however, that the point you are arguing is maybe more about the basis vectors than about the tangent space. So I can see how the tangent space discussion gets in the way of making that point succinctly.
Here, explicitly an affine space is discussed, and there the distinction is indeed not needed, i.e., you usually identify the tangent spaces at any point with the "global vector space" contained in the definition of the affine space, and with that choice you get a flat space.
@Dale is right in warning that often students have problems that the concept of a "position vector" does not exist in the general case of a differentiable manifold, and that it is important that without an additional definition of a connection it is impossible to identify tangent vectors in tangent spaces at different points of the manifold.
An affine space - which was the context of the quoted text - is flat.
PeterDonis said:
Can "flat" even be defined for an affine space?
Well, the obvious connection is flat so ...
Just as an example consider the following picture:
Diagram of a curved coordinate grid with solid red axis t curving left and axis x extending right, dashed red curves, and light blue vectors drawn from point A to points B and C.
It is the affine 2-plane in a curvilinear coordinate system. The position vector field is still defined at each point as long as an origin A is chosen (since it depends on the definition of affine space alone). The components of the position vector field evaluated at point B or C depend on the coordinate/holonomic basis vectors associated to the curvilinear coordinate system at point B or C respectively.
Agreed. But the OP asks first about manifolds, and then specializes the question to a flat manifold. So keeping the distinctions doesn’t hurt and could alleviate some confusion for people who may not be familiar with the portions of the conversation that are valid for all manifolds and the portions that only apply for flat manifolds.
Sure, just saying that the statement was clearly about affine spaces so saying that you disagree with it is a bit confusing as well. I assume you do not disagree with the statement for affine spaces.
Sorry, I should have been clear what I was disagreeing with. I disagree that there is no need to make the distinction. The statement was valid, but without the distinction it could be confusing. So I think there is a need to make the distinction. And it doesn’t hurt your argument to do so.
The affine space uses the obvious connection, making it flat automatically.
Suppose to slightly bend a plane without changing its topology. Do you think the resulting manifold retains the structure of affine space ?
And parallel transport is not path dependent with the obvious connection. Which, as you say, makes it flat.
That is too vague. You can bend a plane and introduce extrinsic curvature but not intrinsic curvature or you can bend it to introduce intrinsic curvature.
Latter case without altering the topology of the plane.
"Topology" is the wrong word to use here. It's the (2D) metric that doesn't alter, which is a stronger condition.
The entire point of my post was that there is no need to make a distinction in an affine space, which was the context of the post. I do not see how you can disagree with this.
In a general manifold there is no translation vector space to identify with the tangent space so the statement clearly does not apply there.
The idea is to introduce intrinsic curvature (hence the 2D metric changes) without changing the topology (the bent plane with its curved intrinsic geometry is still globally homeomorphic to the plane with standard topology).
My question is: can we still define an affine structure for it ? In other words, starting from the set of points, can we define a translation vector space such that the axioms of affine space are met ?
No. Any affine space is flat and a (intrinsically) curved space is not flat by definition.
