How Much Fuel Must a Rocket Burn to Double Its Exhaust Speed?
  • Thread starter Thread starter themadhatter1
    Application Vector
The discussion focuses on determining the fraction of initial mass a rocket must burn to double its exhaust speed. The equation derived from Newton's Second Law relates the rocket's velocity, mass, and exhaust velocity. The user successfully solved part a but struggled with part b, realizing that the initial velocity is zero. The solution involves rearranging the equation to express the remaining mass in terms of the initial mass, leading to the conclusion that the rocket must burn approximately 1/e² of its fuel. The final answer should be presented as the fraction of initial mass burned, expressed as 1 - (m(t)/m(0)).
themadhatter1
A rocket burning it's onboard fuel while moving through space has a velocity v(t) and mass m(t) at time t. If the exhaust gasses escape with velocity ve relative to the rocket , it can be deduced from Newton's Second Law of Motion that
m\frac{dv}{dt}=\frac{dm}{dt}\vec{v_{e}}<br />
a. show that \vec{v}(t)=\vec{v}(0) - ln\frac{m(0)}{m(t)}\vec{v_{e}}
b. For the rocket to accelerate in a straight line from rest to twice the speed of it's own exhaust gasses, what fraction of initial mass would the rocket have to burn as fuel?
I already solved part a, I just can't get part b.
I know that:
2\vec{v_{e}}=\vec{v}(0) - ln\frac{m(0)}{m(t)}\vec{v_{e}}
However, I don't know where to go from here to find the initial mass the rocket would have to burn to achieve this velocity. Any ideas?
It seems to be staring you in the face. You have an equation with essentially one unknown. Where in your equation is your initial mass, and what indicates the fraction of it expended at time t?
Oh wait.
you know v(0)=0.
So this could be arranged to be
m(t)\frac{1}{e^2}=m(0)
so it uses 1/e2 of it's fuel. Is this what you were thinking?
The problem is not asking you to find m(0), the initial mass, but rather the fraction of the initial mass which the rocket would have to burn in order to reach the velocity specified. In your equation, you can treat v_e, m(0), and v(0) as known quantities (you are correct that v(0)=0). You should be solving in terms of the only unknown quantity, m(t). Then, the fraction of the initial mass which the rocket has burned at time t is 1-\frac{m(t)}{m(0)}, so put your answer in that form, ie. 1-\frac{m(t)}{m(0)}=... and that should be it.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 42 ·
