Vector calculus identities and maxwell equations
2 replies · 3K views · last reply
Reloaded47
so we have the identity
[itex]\nabla\times\nabla\phi = 0[/itex]
and from Maxwell's equations we have
[itex]\nabla\times \textbf{E} = -\frac{d\textbf{B}}{dt}[/itex]
But we also have that
[itex]\textbf{E} = -\nabla\phi[/itex]
So the problem I'm having is this
[itex]-\textbf{E} = \nabla\phi[/itex]
which i substitute into the identity
[itex]\nabla\times -\textbf{E} = - ( \nabla\times\textbf{E} ) = 0[/itex]
But this should be
[itex]\nabla\times - \textbf{E} = \frac{d\textbf{B}}{dt}[/itex]
according to maxwell's equations, not zero
which is why I am getting confused
i think there is a good chance I've done somehing silly, i just need someone to point it out
Never mind i figured it out
[itex]\textbf{E} = - \nabla\phi - \frac{d\textbf{A}}{dt}[/itex]
where
[itex]\textbf{B} = \nabla\times\textbf{A}[/itex]
Yours is a good question. The fact is that you define a potential [itex]\phi[/itex] if the field Eis conservative. But a field is conservative if its rotor is zero (irrotational).
This means that considering Maxwell's equation [itex]\nabla \cross \vec{E}=-\frac{\partial \vec{B}}{\partial t}[/itex], you can argue that IF [itex]-\frac{\partial \vec{B}}{\partial t}=0[/itex] then you can define [itex]\phi\backepsilon' \vec{E}=-\nabla\phi[/itex].
However, if you define [itex]\vec{B}=\nabla\cross\vec{A}[/itex], you could write [itex]\nabla \cross \vec{E}=-\frac{\partial \vec{B}}{\partial t}=-\frac{\partial}{\partial t}\nabla\cross\vec{A}\Rightarrow \nabla\cross\{\vec{E}+\frac{\partial\vec{A}}{\partial t}\}=0[/itex] so that the field [itex]\vec{E}+\frac{\partial\vec{A}}{\partial t}[/itex] is irrotational, then conservative, so that [itex]\vec{E}+\frac{\partial\vec{A}}{\partial t}=-\nabla\phi\Rightarrow\vec{E}=-\nabla\phi-\frac{\partial\vec{A}}{\partial t}[/itex]
This is a more general definition of the potential of the electric field that fits with Maxwell's equations. However, there is a term missing in my last expression related to a gauge transformation, but since it is a term related to the frame of reference, setting proper condition it can be put to zero.
