Vector Calculus Question (I don't understand)
The discussion revolves around the transformation T defined on the square D* = [0,1]x[0,1] by T(u,v)=(-u^2+4u, v). The image of this transformation is identified as D = [0,3] x [0,1], and it is confirmed that T is one-to-one. Participants explore methods to demonstrate the one-to-one nature of T, suggesting that the outputs can be analyzed to show that if T(u1, v1) = T(u2, v2), then (u1, v1) must equal (u2, v2). The mapping of u to a parabola and v remaining unchanged simplifies the analysis. Overall, the transformation effectively maps the square into a rectangle while maintaining a one-to-one correspondence.
der.physika
Let D* = [0,1]x[0,1] and define T on D* by T(u,v)=(-u^2+4u, v). Find the image D. Is T one-to one
I have no idea... I don't know how to do it.
The solution is [0,3] x [0,1]... yes it is one to one.
am I supposed to say det A does not equal zero or use the u=u' v=v' approach?
and... how do I find D? i don't know how to go about this.
Could someone give me a similar example and solve that?
This seems pretty straightforward to me, as the image vector doesn't have u and v tangled together. For fixed u, T maps v to v. For fixed v, T maps u to -u^2 + 4u, and this graph is a parabola.
This is kind of a simple-minded way to look at this problem, but I think it will work.
Okay... so I took your advice.
so I thought about what you said
so T(u,v) maps u => -u^2 + 4u
and v to v
so for u [0,1] is the interval... so that means [0, -1+4] = [0,3]
for v [0,1] goes to [0,1]
[0,3] x [0,1] so that means... it maps the square into a rectangle.
But... how do I show that the mapping is one-to one??
Let's call the outputs (w, z), so that T(u, v) = (w, z), with w = -u2 + 4u and z = v. Show that (w1, z1) = (w2, z2) ==> (u1, v1) = (u2, v2).
It's also helpful to look at the portion of the parabola for which 0 <= u <= 1. Quadratic functions aren't normally one-to-one, but if the domain is limited in the right way, the limit domain version can be one-to-one.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 58 ·
