Vector calculus question - surface of ellipsoid
Froskoy
Let [itex]E[/itex] be the ellipsoid
[tex]\frac{x^2}{a^2}+\frac{y^2}{b^2}+z^2=1[/tex]
where [itex]a>\sqrt{2}[/itex] and [itex]b>\sqrt{2}[/itex]. Let S be the part of the surface of [itex]E[/itex] defined by [itex]0\le x\le1, 0\le y\le1, z>0[/itex] and let [itex]\mathbf{F}[/itex] be the vector field defined by [itex]\mathbf{F}=(-y,x,0)[/itex]. Given that the surface area element of [itex]S[/itex] is given by
[tex]d \mathbf{S} = \left({ \frac{x}{a^2z}, \frac{y}{b^2z}, 1 } \right) dxdy[/tex]
find [itex]\int_S\mathbf{F}.d\mathbf{S}[/itex] in the case [itex]a/ne b[/itex]
Scalar product
[tex] \int_S\mathbf{F}.d\mathbf{S}=\int_S(-y,x,0).\left({ \frac{x}{a^2z}, \frac{y}{b^2z}, 1 }\right) dxdy<br /> <br /> =\int_{y=0}^1\int_{x=0}^1\frac{-xy}{a^2z}+\frac{xy}{b^2z}dxdy<br /> <br /> =\left({\frac{1}{b^2}-\frac{1}{a^2}}\right)\int_{y=0}^1\int_{x=0}^1\frac{xy}{z}dxdy[/tex]
It's at this point I'm not sure what to do with the parameter [itex]z[/itex]. I tried continuing, treating [itex]z[/itex] as constant to get
[tex] \int_S \mathbf{F}.d\mathbf{S}= \frac{1}{4z} \left({ \frac{1}{b^2}- \frac{1}{a^2}}\right)[/tex]
but don't like the fact there is a [itex]z[/itex] there? Would converting to spherical coordinates help? If so, how would you do it?
With very many thanks,
Froskoy.
Since you know z is not a constant, it makes no sense at all to "treat z as constant".
You are told that
[tex]\frac{x^2}{a^2}+ \frac{y^2}{b^2}+ z^2= 1[/tex]
so
[tex]z= \pm\sqrt{1- \frac{x^2}{a^2}- \frac{y^2}{b^2}[/tex]
Do the z> 0 and z< 0 parts separately.
I would NOT use spherical coordinates but a variation on cylindrical coordinates might help. Taking z= 0, we see that the ellipsoid projects to the ellipse [itex]x^2/a^2+ y^2/b^2= 1[/itex]. Let [itex]x= a rcos(t)[/itex], [itex]y= b rsin(t)[/itex]. The Jacobian is [tex]\left|\begin{array}{cc}\frac{\partial x}{\partial r} & \frac{\partial x}{\partial t} \\ \frac{\partial y}{\partial r} & \frac{\partial y}{\partial t}\end{array}\right|= \left|\begin{array}{cc}a cos(t) & -a rsin(t) \\ b sin(t) & b rcos(t)\end{array}\right|= ab cos^2(t)+ ab sin^2(t)= ab[/tex]
so that [itex]dxdy= ab dr dt[/itex]
