How Do You Calculate the Effective Speed of a Tailwind for a Westward Cyclist?
To calculate the effective speed of a tailwind for a westward cyclist, the cyclist's speed of 5.6 m/s is treated as a negative x-component on a Cartesian plane. The northeast wind's velocity is broken down into its x and y components, with the x-component calculated as approximately 7.1 m/s. When combining these components, the resultant x-component (Rx) is found by subtracting the cyclist's speed from the wind's x-component, resulting in 1.5 m/s. This approach illustrates how the wind slightly aids the cyclist's speed, despite the cyclist's westward direction. The effective speed of the tailwind is thus determined through vector addition of the respective components.
Coco12
A cyclist head due west on a straight road at 5.6m/s. A northeast wind is blowing at 10m/s. What is the effective speed of the tailwind?(resultant)
Cos 45 10
Sin 45 10
Basically I broke it down into its x and y components. Then added them together to the Rx and Ry and used Pythagorean to find the resultant. I just have one question though: when adding the x components for the wind and the cyclist speed. Would the Rx be -5.6m/s + 7.1( 7.1 is derived from cos 45 degrees *10) = 1.5? Or would the 5.6 be positive?
To help you answer your question, it might help to write out explicit expressions for the vectors representing the cyclist and the wind velocities.
I did. Rx=ax+bx
Ry=ay +by
I'm just wondering since it's 5.6 m/s due west which on a Cartesian plane would be a negative x whether I would incorporate the negative when trying to find rx
Coco12 said:
I did. Rx=ax+bx
Ry=ay +by
Yes, you can represent the velocity vector of the cyclist as ##\vec{C} = -5.6 \hat{x}## and that of the wind as ##\vec{W} = (10 \cos 45)\hat{x} + (10 \sin 45) \hat{y}##. Now, as you said, just add components to get the resultant.
From a more conceptual point of view, imagine a game of tug of war. Person A pulls to left with force 5.6N and person B to right with force 10cos45 ≈ 7.1 N. The person pulling to right wins, but only marginally. (winning by 7.1 - 5.6, not 7.1 + 5.6)
Likes 1 person
21K
