Vector fields wedge product vs covector field
The discussion revolves around the differences between the wedge product of independent vector fields and covector fields (1-forms) in the context of differentiable manifolds. Participants explore theoretical implications, transformations, and dimensionality related to these mathematical constructs.
  • Some participants note that both the wedge product of ##(n-1)## independent vector fields and covector fields can define an ##(n-1)##-dimensional distribution on a tangent bundle.
  • One participant suggests that under special linear transformations, the two constructs behave identically, but they may differ under reflections.
  • Reference to R. Penrose's work indicates that a 1-form is considered a type of density, while the wedge product of vector fields is not.
  • Several participants express uncertainty about the original question and the relevance of the referenced sections from Penrose's book.
  • There is a discussion about the dimensionality of the tangent space and whether it is possible to have more independent vector fields than the dimension of the manifold.
  • Participants mention that the algebra of vector fields is infinite dimensional and discuss the vector space structure of smooth sections on the tangent bundle.
  • One participant introduces the concept of Killing Vector Fields on the 2-sphere and questions whether they form a vector subspace of the vector fields defined on the sphere.
Participants express various viewpoints, and there is no clear consensus on the differences between the wedge product and covector fields, as well as the implications of dimensionality in these contexts. The discussion remains unresolved on several points, particularly regarding the interpretations of density and the nature of vector spaces.
There are limitations in the clarity of the original question and the relevance of the references provided. Some participants also note the need for further clarification on the definitions and properties of the mathematical constructs discussed.
cianfa72
TL;DR
About the difference between the wedge product of ##(n-1)## independent vector fields vs a covector field (1-form)
There are two ways to assign a ##(n-1)##-dimensional distribution on the tangent bundle built over a differentiable manifold of dimension ##n##. Namely it can be assigned either via the wedge product of ##(n-1)## independent vector fields or via a covector field (1-form).
Which is the difference between them ?
Under special linear transformations they should behave identically. However, under reflections I believe they behave differently. E.g. under inversion in the x-direction ##\hat{x}\wedge \hat{y}\to -\hat{x}\wedge \hat{y}## while ##(\hat{z}•)\to (\hat{z}•)##. (Notation: ##(\hat{z}•):\vec{v}\mapsto \hat{z}•\vec{v}##.)
I took a look at R. Penrose book The Road to Reality section 12.6. He claims that a 1-form should be thought of as a kind of density while the wedge product of ##(n-1)## vectors should not.
To me it isn't clear what you want to know. The reference doesn't help because it seems to be about something different (the exterior derivative).
Sorry, the relevant sections from that source are actually 12.4 (p. 228 in my edition) and 12.5.
Ok, but what is your question?
From that section, I think I got the answer: a wedge product of ##n-1## independent vector fields can't be understood as a "density" like a 1-form (covector field).
Btw, the tangent space at each point on a ##n##-dimensional differentiable manifold has itself dimension ##n## (i.e. the maximum number of linear independent vectors at point P is ##n##). Coming to vector fields, is it possible to have ## m > n## independent vector fields ?
Yes, but keep in mind that by density he means something that can be integrated.
Yes, the algebra of vector fields is infinite dimensional.
Ok.
The set of vector fields (i.e. the set of smooth sections on the tangent bundle over the base manifold) can be assigned a vector space structure. Is this vector space infinite dimensional ?
Yes, that is what I said. It is infinite dimensional over the real numbers. As an example take vector fields on the line. They are of the form ##a(x)\frac{\partial}{\partial x}##. Then all of these ##\frac{\partial}{\partial x}, x\frac{\partial}{\partial x}, \dots, x^n\frac{\partial}{\partial x},\dots## are indipendent.
Btw, maybe a bit off topic, consider the 2-sphere ##\mathbb S^2## and the set of its Killing Vector Fields (KVFs).
Any such KVF generates rotations about a specific axis. They form a subset of the vector space of vector fields ##\Gamma(T\mathbb S^2)## defined on ##\mathbb S^2##.
Is it a vector subspace of ##\Gamma(T\mathbb S^2)## with dimension 3 ?
Sorry, I was thinking about the following: ##C^{\infty}(\mathbb R)## isn't a field, hence the set of vector fields on ##\mathbb R## as manifold can't be a vector space over ##C^{\infty}(\mathbb R)##. Nevertheless it is infinite dimensional vector space over ##\mathbb R##.
Indeed your ##a(x)\frac{\partial}{\partial x}, a(x) \in C^{\infty}(\mathbb R)## are vector fields (i.e. they are smooth sections of ##T\mathbb R##) and the unique ##\mathbb R ##-linear combination of ##\frac{\partial}{\partial x}, x\frac{\partial}{\partial x}, \dots, x^n\frac{\partial}{\partial x},\dots## that gives the null vector field consists of all zeros (i.e. they are ##\mathbb R##-linear independent). As an aside, smooth vector fields form a ##C^{\infty}(M)##-module -- MSE.
Does it make sense?
  • · Replies 73 ·
  • · Replies 30 ·
