Vector space, basis, linear operator
10 replies · 4K views
boombaby
Let V be a vector space of dimension n. And the linear operators E=A^0, A^1, A^2, ... A^(n-1) are linearly independent. Prove that there exists a v in V such that V=<v, Av, A^2v, ..., A^(n-1)v>
Here are something that I tried.
the degree of the minimal polynomials p(t) such that p(A)=0 is larger than n-1. I wanted to start the proof from here but have no idea how to proceed.
assume V is over complex field C so that there is an eigenvector. However, it seems that this is also not the disired v to make them independent.
Any hint? Thanks a lot
Are you using <,> to denote span? If so, then it suffices to find a v such that {v, Av, ..., An-1v} is linearly independent. Stated differently, we want to make sure that whenever k0, k1, ..., kn-1 are scalars that are not all zero, then
[tex]k_0 + k_1 Av + \cdots + k_{n-1} A^{n-1}v \neq 0[/tex].
Or, equivalently,
[tex](k_0 + k_1 A + \cdots + k_{n-1} A^{n-1})v \neq 0 \iff v \not\in \ker(k_0 + k_1 A + \cdots + k_{n-1} A^{n-1})[/tex].
But what can you say about ker(k0+ k1 A + ... + kn-1 An-1)?
thanks for the hints! Here's what I think,
so k0E+k1A+...+kn-1An-1 (called [tex]B_{k_{1},k_{2},..,k_{n-1}}[/tex])cannot be the 0 operator (since E, A, ..,An-1 are linearly independent), which implies that [tex]dim(Ker\! B_{k_{1},k_{2},..,k_{n-1}}) \leq n-1[/tex]
(**) suppose we have V1, V2 as two proper sub space of V, then we can find a vector in V which is neither in V1 nor V2
(assume we cannot, find two vectors such that [tex]x\in V_{1} \: x\notin V_{2} \: y\in V_{2} \: y\notin V_{1}[/tex] x+y will give a contration)
If we have only finitely many [tex]B_{k_{1},k_{2},..,k_{n-1}}[/tex] I can find a v such that [tex]B_{k_{1},k_{2},..,k_{n-1}}v\neq 0 \: for\,all\: B_{k_{1},k_{2},..,k_{n-1}}[/tex] according to (**). Does this remain true if there are countably many or uncountably many subspace? I've no idea...
Am I thinking right?...
Thanks
What is your definition of "linearly independent" for linear operators?
Presumably linear independence refers to independence in the vector space L(V) of linear operators on V.
No, but fortunately we only need to consider finitely many [itex]B_{k_{1},k_{2},..,k_{n-1}}[/itex]. Consider the irreducible factors of the minimal polynomial of T.
it's the same as other things I think...All the linear operators on V over field K forms a vector space, called L(V), and A_1,...,A_s in L(V) are linearly independent iff k_1*A_1+...k_s*A_s=0 implies k_1=...=k_s=0...
Edit:
I'll have a look at the irreducible factors...Thanks
can you explain it a little more? I can not figure it out...
Thanks
You're going to want to use the rational canonical decomposition from here.
Ah...it seems that there are lots of materials under the topic "rational canonical" that I cannot understand quite fast right now. I'll back to this question later. Anyway, Thanks a lot for your help!
Which is the same, then, as saying that if v is any non-zero vector, {A_1v, A_2v, ..., A_s v} are independent in V.
No, this is not true. if some Ai v=0, then they are not independent.
