Parametric Equation of Tangent Line for f(t)= (t2,1/t) at t=2
  • Thread starter Thread starter Loppyfoot
    Vector
The discussion focuses on finding the parametric equation of the tangent line for the curve defined by f(t) = (t^2, 1/t) at t=2. The gradient of the function is determined to be f'(t) = <2t, -1/t^2>, and after substituting t=2, the slope is calculated. The point on the curve at t=2 is found to be (4, 1/4), leading to the parametric equation of the tangent line as f(t) = (4, 1/4) + t<4, -1/4>. A suggestion is made to simplify the equation to f(t) = (4, 1/4) + t<1, -1>. The conversation emphasizes the importance of using the correct parameter for clarity.
Loppyfoot
The function f(t)= (t2,1/t) represents a curve in the plane parametrically.
Write an equation in parametric form for the tangent line to this curve at the point where t=2
I can solve the gradient from an implicit equation, but solving from a parametric equation confuses me.
Would the gradient of f(t)= <2t, -1/t2>?
Then plug in the value t=2 to get the point?
Would that be correct?
Thanks for the input..
Hi Loppyfoot! :smile:
It's parallel to that …
the gradient itself is a multiple of that, and the exact multiple depends on the choice of parameter (t in this case) …
fortunately the multiple does't matter in this case. :wink:
Yes, that'll give you the slope of the tangent line, from which you can get its equation in parametric form, as asked for (with a different parameter, of course!) :smile:
Alright!
So the final answer after plugging in t=2 to get the slope, and f(2) to get the points, the parametric equation would be:
f(t)= (4,1/4) + t<4,-1/4>
Thanks a lot TIny TIm!
Neater would be to simplify it … f(t)= (4,1/4) + t<1,-1> :wink:
(and possibly to use a different parameter)
Oh good point. thanks!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
9K
