Vector torque problem: Force applied to a disc
6 replies · 5K views · last reply
jwbensin
A force of magnitude 50N is applied at the bottom point Q of a disk of radius 8m that is pinned at P
(leftŸmost point)
See attached picture
(a) Find the angle between the force and the vector from P to Q.
(b) Find the magnitude of the applied torque.
|T| = |F|sin(Theta)*|r|[/B]
So for part (a) I said the angle was 85 degrees but apparently that's wrong? At least according to my colleges online homework program. honestly don't know how to start part (b)
  • Diagram of a yellow disk with pivot point P on its leftmost edge and a force vector of magnitude 50 N applied at the bottom point Q, the force directed down and to the left at 40 degrees below a dashed horizontal line.
Draw the vector from P to Q. Then move it so that its tail is at the same point as the tail of the force vector. Now what do you get for an angle between them?
You set a usual OXYZ reference system, with origin at point P, and note that the coordinates of point Q are: Q(0,8,-8), and the vector position corresponding to point Q, remains:
r = PQ = <8,-8,0>
Then, note that the components of the force applied at point Q are:
F = <50sin(40º), -50cos(40º), 0>.
Then, to calculate the torque with respect to an axis parallel to the OX axis passing through point P, you have to solve the vector product:
T = r x F.
95 Degrees?
jwbensin said:
95 Degrees?
Yes. Now you have everything you need to substitute into your equation for |T|.
So would I just simply do |T| = 50sin(95)*8sqrt2 or am I missing something?
I think that would do it.
