Solving Vectors: Tips and Tricks for Effective Problem Solving
  • Thread starter Thread starter link107
    Vectors
The discussion focuses on solving a vector problem involving a man's displacement after walking two segments at specified angles. The net displacement is calculated to be approximately 9.3 meters at an angle of 120 degrees from the positive x-axis. Participants suggest methods for effectively solving vector problems, including plotting vectors, using right triangles, and resolving vectors into x and y components. The process involves calculating the components, adding them, and then applying the Pythagorean theorem for magnitude and arctan for direction. The conversation also touches on confusion regarding applying similar problem-solving techniques to different concepts, such as moment of inertia and double integration.
link107
A man walks 5 m at 37degrees north of east and then 10 m at 60degrees
west of north. What is the magnitude and direction of his net
displacement
The answer is around 9.3m at around 120 degrees angle on the +x axis
none
http://img825.imageshack.us/img825/2570/vectors2.png
I have no idea what to do after I plot out the vector and connect tip to head. Can someone explain to me how to solve for vectors effectively?
Thank you
One way to go after it is to draw right triangles and use them to find the end points in XY coordinates of what you have in the drawing. See if you can figure out what I'm talking about.
Another way is to resolve the vectors along x and y axis
5m 37degrees north of east can be written as cos(37)*5 along x-axis and sin(37)*5 along y-axis
similarly do it for other vector..
now add components along x and y-axis seperately and get new measurements along x and y axis
now use x2+y2 = (magnitude of resultant)2
for magnitude
and arctan(y/x) for direction of resultant vector.(x and y are values of new measurements along x and y axis) (angle obtained is the angle from +ve x axis)
for magnitude
You really surprise me. You can't figure out how to obtain the distance between two points given their coordinates, yet you advise others precisely on how this is done.
Did i make a mistake??
No you did not. That's why I am surprised. Why can't you apply this same knowledge to your problem about the moment of inertia?
Basically i got it
But pls help me with the double integration
i mean how is it done??
  • · Replies 19 ·
  • · Replies 38 ·
