Velocity, acceleration, collision
20 replies · 4K views · last reply
PhysicsBoyMan
Speedy Sue, driving at 30m/s, enters a one way tunnel. She observes a slo-moving van 155m ahead traveling at 5m/s. Sue applies her brake and accelerates at 2m/s. Will there be a collision? If yes, determine how far into the tunnel and at what time. If no, determine the distance of closest approach between Sue's car and the van.
V1 = 30m/s
V2 = 5m/s
x = 155m
a= -2m/s2
I attempted to make Δxsue = Δxvan.
I used Δx = volt + 1/2 at2.
I combined like terms and tried to use the quadratic equation. I had a negative number under my square root.
I am wondering if this is the right approach.
I used the same formula for Sue only, and found that it would take 6.63s to move the 155m with her velocity and acceleration.
I've been at this for a long time and have tried many different ways. I do have a list of equations for when acceleration is constant. A little bit of guidance here would help a lot, I have spent hours now and an outside perspective would be refreshing.
V1 = 30m/s
V2 = 5m/s
x = 155m
a= -2m/s2
Yes, that's the correct approach. :smile:
That's one equation. The one for Speedy Sue. What's the other equation?
'Sounds like you are on the right track. A quadratic equation is involved. :smile:
Something must have went wrong around there then. The value under my square root was positive.
Please show your work thus far and maybe we can point you in the right direction.
That won't help you a whole lot. By the time Sue is 155 meters into the tunnel, the Van isn't at that location anymore. It moved.
Try going back to solving for t and we'll see where that takes us.
By the way, just to be clear, there isn't anything fundamentally wrong with getting negative numbers under the square root for problems like these. It would just mean that a collision won't happen. It means that there is no such (real) t that exists that would cause the displacements to be equal.
However, in this particular problem, the sign under the square root is positive, according to my calculations. So you'll have to show your work before we can continue.
That's a great point Collinsmark! Thanks for teaching that.
This is how far I got. To get a negative for 4ac either a or c are wrong. A is -1 it seems straight forward I think my c is wrong. The way I learned to do delta x is x final - x initial so I'm not sure where I went wrong but that must be the problem I would think.
Thanks for the help.
Handwritten whiteboard working for a kinematics problem: Sue's and Van's displacement equations combined into a quadratic, with the note 'Negative under square root' below.
screen capture
It looks like you've got an initial position ##x_o## of 155 m for the van, which is correct, but it looks like you've set ##\Delta x## equal to 155 m for Sue.
You should be setting ##x_{Sue}=x_{van}##,
but it looks like instead you're setting ##x_{van}=0##.
Instead of using
##\Delta x=v_ot+\frac{1}{2}at^2##
try using
##x=x_o+v_ot+\frac{1}{2}at^2##
for both Sue and the van.
Handwritten whiteboard work on a car-and-van problem: given values listed at left, Sue's displacement equation with a quadratic in t, the van's constant-velocity equation, and a combined quadratic with the note negative under the square root.
screen capture
Hmm.
Let's step back a bit.
Equation for Sue:
[itex]x = v_0 t + \frac{1}{2}a t^2[/itex]
You had that, however, don't put in 155 m for [itex]x[/itex] in that equation. We don't know what [itex]x[/itex] is. At least we don't know what it is yet. It's not 155 m though. It's farther than that. It's the distance that Speedy Sue will travel before reaching the van. But remember the van is moving, so that distance is something greater than 155 meters.
But again, don't worry about its actual value yet.
Equation for the van:
That one needs work. Try that equation again. Recall the van is not accelerating. It's simply moving at a constant velocity. What's the relationship between displacement and time of something moving at a constant velocity?
For this equation you'll want to specify the position of the van relative to the entrance to the tunnel (That way Sue's displacement and the van's displacement are both relative to the same location). And it's this equation where the 155 m fits in. :wink:
I forgot to take a picture of the complete solution, but I finished it thanks to you guys. That one took a long time!
I used x=v0t+12at2 for sue and x=vt for van. Sue's x position was unknown as you say, as opposed to 150m. The time ended up being 11.something seconds.
I will be more careful in the future and think before I declare something to be true in my equations.
Thanks again!
There will be No collision.and the distance between them will be 5 m.
V1 = 30m/s
V2 = 5m/s
x = 155m
a= -2m/s2
Firtly we need to find how much time sue's car take to stop
V=u+at
0=30+(-2*t)
-30=-2t
t=15
in that 15 sec how much the slow van will go
s=vt=15*5=75
and after acclerating at -2ms-2 sues car will stop after 15 s and the distance the car will reach
S=ut+1/2at2=30*15+1/2*(-2)*(15)2=225m
s=vt=15*5=75
and after 15 s the van will be from beginig of car's position (155+75)=230m
so there will be no collision cause the car goes less distance than 230 m as the car goes 225m
and the closet distance between them is (230-225)=5 m
do it like that
This approach will not work. Indeed, you got the wrong answer. They collide before Sue comes to a stop.
[Q..UOTE="haruspex, post: 5258893, member: 334404"]This approach will not work. Indeed, you got the wrong answer. They collide before Sue comes to a stop.[/QUOTE]
Ok.
please do the right answer for me.
your working approach.
Sbr:132 said:
Ok.
Consider the problem in the reference frame of the lead vehicle. How far does Sue start from it and how is Sue moving in relation to it? At their closest point, what will the relative velocity be?
V=u+at
0=30+(-2*t)
-30=-2t
t=15
You calculate 15 s for Sue to come to a stop. The OP calculated approximately 11 s before a collision, so if he's right and you're right, Sue will hit the van before she can come to a stop!
We're supposed to be helping the OP, not solving the problem.
Hint: The position-time graph of Sue's motion is a concave-down parabola with the vertex at t = 15 s. The van's position-time graph is a straight line with a slope of 5 m/s. The line crosses the parabola in two places,
Use
for both Sue and the van. Then set the two values of ##x## equal to each other and solve for ##t##. You will get two times, one for each intersection of the parabola with the line. One before the vertex, the other after.
Mister T said:
Use
V=u+at
0=30+(-2*t)
-30=-2t
t=15
s=vt=15*5=75
if u have any solution please do that sum.
Now I really want to understand it.
wather he is right or me.
we have been around this already. That is your assumption, but it is not right. In the final moments before Sue stops, Sue will be moving more slowly than the van, so they will be getting further apart. Therefore the closest approach is before Sue stops.
Sbr:132 said:
Now I really want to understand it.wather he is right or me.
Mister T said:
Use
##x_{Sue}=(0)+(30)t+\frac{1}{2}(-2)t^2##,
##x_{van}=(155)+(5)t+\frac{1}{2}(0)t^2##.
look you almost 40 yrs elder than me.
if my sum below is worng do the right sum for me mathematically and prove that there will be a collision.I'm just a college student.and I want to understand it.
my sum is below
V=u+at
0=30+(-2*t)
-30=-2t
t=15
again
again
s=vt=15*5=75
and the distance between them is (230-225)=5 m
Follow the instructions I gave in Post #18. If you have specific questions about that procedure ask and we will help. But we won't do the work for you.
(The basic flaw in your method is that you calculate the time it takes Sue to stop. Instead the solution of the problem involves calculating the time it takes Sue to collide. Stopping is the not necessarily the same thing as colliding. We will not attempt to prove that we are right, but we will try to guide you towards proving it to yourself. We won't do the work for you. We will help you do the work for yourself.)
@Sbr:132 , you keep claiming to calculate the time it takes Sue to stop, but what you actually calculate is the time it takes Sue to stop assuming she does not first hit the van.
Try this: calculate where Sue and the van will be after 12 seconds.
