Velocity as a function of distance [v(x)]
  • Thread starter Thread starter BitterX
    Function Velocity
3 replies · 2K views
BitterX
a body with mass M moves across a plane with friction
friction constant:
[itex]\mu = \lambda x^2[/itex]
the body starts at x=0
with velocity v0
find at what x
the body stops
and what was the velocity half way there.
[itex]v^2=v_0^2+2a\Delta x[/itex]
obviously,
[itex]F(x)=mg\mu = mg\lambda x^2[/itex]
so
[itex]a(x)=g \lambda x^2[/itex]
so in the equation [itex]v^2=v_0^2+2a\Delta x[/itex]
I get
[itex]v^2=v_0^2+2g\lambda x^3[/itex]the Question is, can I use this equation? the acceleration is not constant and this equation
depend on the fact that [itex]x=v_0t+ \frac{a}{2}t^2[/itex]
and [itex]v=v_0+at[/itex]
(and it's not true for non-constant acceleration)
if I cant, how can I integrate the acceleration?
or how do I get v(x)?
Thanks.
EDIT:
I used [itex]a= v\frac{dv}{dx}[/itex]
therefore
[itex]vdv=adx[/itex]
[itex]\int_{v_0}^{v(x)}{vdv} = g\lambda \int_{0}^{x}{x^2}[/itex]
[itex]\frac{1}{2} ( v(x)^2- v_0^2) =\frac{1}{3} g\lambda x^3[/itex]
[itex]v(x)^2=v_0^2+\frac{2}{3}g\lambda x^3[/itex]
does that seem right?
I don't see anything wrong with your edited solution.
friction constant:
with velocity v0
obviously,
so
therefore
Does the friction increase speed?
Remember that velocity, acceleration and force are all vectors. You need to use proper signs with them.
ehild
ah, of course... it's with a minus :)
on paper I actually did it with a minus. Thanks for pointing it out though!
