Velocity feedback damping in aircraft
Velocity feedback damping in aircraft systems is crucial for enhancing control response, particularly in pitch hold scenarios. By utilizing a pitch rate gyro, the system can achieve improved damping characteristics, allowing for quicker error correction compared to traditional pitch sensors. Additionally, in auxiliary power units (APUs), speed sensors provide feedback to the control unit, optimizing APU speed management. This integration of feedback mechanisms is essential for maintaining stability and performance in aircraft operations.
  • Understanding of aircraft control systems
  • Knowledge of pitch rate gyros and their function
  • Familiarity with auxiliary power units (APUs) and their control mechanisms
  • Basic principles of feedback control systems
  • Research the role of pitch rate gyros in aircraft stability
  • Explore the design and function of auxiliary power units (APUs)
  • Study feedback control systems in engineering applications
  • Investigate velocity feedback damping techniques in other aerospace systems
Aerospace engineers, aircraft system designers, and students studying control systems in aviation will benefit from this discussion on velocity feedback damping in aircraft systems.
Emzielou83
Describe velocity feedback damping in relation to aircraft systems?
my attempt at an answer:
I know what damping is, and i know what velocity feedback is, I just can see how they fit together. I think it's something along the lines of;
an auxilery power unit has a speed sensor attached, this in turn feeds the auxilery poer control unit which uses the signal to control the speed of the APU.
OR;
synchro's used in a HSI have a pick off of which the signal is fed back to stop the synchro 'hunting'
Can someone help me? I think I'm completely lost
OR;
I was initially thinking that it might be analogous to speed sensitive steering in cars (you can google that to see what it is). But then I googled velocity feedback damping +aircraft, and got some interesting hits. Have a look through the hit list to see it it gets you on the right track:
http://www.google.com/search?source...01US302&q=velocity+feedback+damping++aircraft
Feed back dampening of an aircraft can best be explained with a pitch hold example. With an unaugmented pitch hold the transient response (response time) may not be as desired. So to augment the system and gain better damping characteristics, the pitch rate gyro state can be sent back which gives the error of the system much faster than the pitch sensor does.
And of course with a velocity hold, acceleration would be fed back to quicken the response...
  • · Replies 131 ·
  • · Replies 23 ·
  • · Replies 17 ·
