Velocity is proportional to distance
The discussion centers on the relationship between velocity and displacement for an object starting from rest, where velocity is proportional to displacement. The equation derived is v = C * √(x), indicating that velocity is proportional to the square root of displacement when acceleration is not constant. Participants clarify that if acceleration is constant, the relationship would be v² = v₀² + 2aₐ(x - x₀), leading to a different interpretation of proportionality. The consensus is that the textbook may contain an error regarding the assumption of constant acceleration.
  • Understanding of kinematic equations, specifically v² = v₀² + 2aₐ(x - x₀)
  • Basic knowledge of calculus and differential equations
  • Familiarity with the concept of proportional relationships in physics
  • Ability to interpret and analyze motion graphs
  • Study the implications of non-constant acceleration on motion equations
  • Learn about differential equations in the context of motion
  • Explore the concept of proportionality in physics, focusing on velocity and displacement
  • Review kinematic principles in introductory physics textbooks for clarity on acceleration assumptions
Students studying physics, particularly those focusing on kinematics, educators seeking to clarify concepts of motion, and anyone interested in the mathematical relationships between velocity and displacement.
nobahar
An object starts from rest at the origin and moves in the positive x direction. The velocity is proportional to the displacment. I am trying to find the equation linking velocity to displacement.
Since the object starts at rest and then moves in the positive direction, acceleration is non-zero. The chapter in the textbook concerns constant acceleration. So, I think v2= vi2+ 2a[x-xi] would be appropriate. vi is initial velocity and xi is initial displacement.
Setting both the initial velocity and initial displacement to zero gives v = sqrt(2ax). Does this count as velocity proportional to displacement? I found online this type of thing being referred to as proportional to the square root.
Any help appreciated. Apologies for lack of latex. This isn't on a computer!
If velocity is proportional to displacement, then acceleration is not constant. In stead you would have v = kx for some constant k (with units 1/time). This is a differential equation that can be solved (note that if x=0, the object will not move, you need some initial displacement).
Hi Orodurin, thanks for the reply.
The chapter concerns kinematics with either zero or constant acceleration. It doesn't even assume much familiarity with calculus so I can't see that the question would require one to solve a differential equation. That's why I thought acceleration would have to be constant and non-zero.
The only solution I can find is the one from my original post:
v^2 = v_{i}^2 + 2a_c(x - x_{i})
initial velocity is zero, initial displacement is zero, therefore:
v^2 = 2a_cx
which gives:
v = \sqrt{2a_cx}
since 2 and acceleration are both constants:
v = C * \sqrt(x)
Can this be considered proportional? Perhaps at a stretch?
nobahar said:
The velocity is proportional to the displacement. I am trying to find the equation linking velocity to displacement.
That seems pretty simple. If y is proportional to x, what equation can you write for y as a function of x? Are you sure that's a precise statement of the problem?
v^2 = 2a_cx
which gives:
v = \sqrt{2a_cx}
v = C * \sqrt(x)
in my opinion, v^2 should be proportional to displacement, if acceleration is constant, as shown by you just now, which is v^2 = v_{i}^2 + 2a_c(x - x_{i}). Is it possible that there is a misprint on the textbook?
If acceleration is constant - but here, it is not.
We can see this in post 1 already, where velocity would follow the square root of displacement.
Thanks for the replies. I am not sure if it is an error in the book, but perhaps the acceleration is not constant and the relationship is simply |v| = kx and I do not need anything more "fancy" to solve the problem (such as differential equations), I might be neglecting something obvious.
The question is as follows: "... tell whether the object's position x doubles as the clock reading t doubles... The object starts from rest at the origin at t=0 and travels in the positive x direction. Its speed is proportional to its distance from the origin."
Don't worry: If the distance doubles as time doubles then the acceleration would have to be zero, since the average velocities would have to be the same. But the problem involves non-zero velocity, and so the distance does not double as the time doubles. Kind of obvious and I completely missed it. Thanks for all the replies.
  • · Replies 38 ·
  • · Replies 17 ·
