How Do Aerodynamics Affect an Airplane's Lift and Drag Forces?
The discussion focuses on calculating the lift force and drag force acting on an airplane with a mass of 300 tonnes, ascending at a constant velocity of 100 m/s at a 10° angle. The thrust produced by the engines is 9000 kN. To determine the lift force, one must analyze the vertical forces, which include the upward lift, the weight of the airplane, and the vertical component of thrust. The resistance to motion, or drag force, can be calculated by resolving the thrust into its horizontal and vertical components using trigonometric functions.
  • Understanding of Newton's laws of motion
  • Basic knowledge of trigonometric functions (sine and cosine)
  • Familiarity with force components in physics
  • Concept of lift and drag forces in aerodynamics
  • Calculate lift force using the formula: Lift = Weight + Vertical component of thrust
  • Determine drag force using horizontal component of thrust and the equations of motion
  • Explore the relationship between angle of ascent and lift/drag forces
  • Study the effects of different thrust values on lift and drag in various flight conditions
Aerospace engineers, physics students, and anyone interested in understanding the principles of aerodynamics related to lift and drag forces in aviation.
emperror123
1. an aeroplane of mass 300 tonnes during ascent travels at a constant velocity of 100 m/s. its angle of ascent is 10° to the horizontal. the trust produced by engines is 9000kN. Determine
i)the lift force acting on the wings
ii) the resistance to motion
i were trying to use f=ma, but the question didnt mention about the time, is it we need to convert 9000kN to acceleration in order to get time is second or can i get it from the question above, in other way i research via google with other website, some get F = 0N, is it possible?
secondly, the resistance is it = lift force or is it a drag force
thank
Welcome to PF, emperror.
The plane is not accelerating, so both the vertical and horizontal forces must be zero. For the vertical forces, you have a component of thrust upward, lift upward and the weight downward. You also have a component of the drag (resistance to motion) downward. Looks like two unknowns there, so you will have to write a similar equation for the horizontal forces and solve the two as a system.
u mean i have to find the vertical axis 1st before i can do the horizontal axis?
and i can assume that the velocity with angle with 0N?
thrust is it on horizontal or vertical? cause u said that the thrust is upward (y-axis), make me doubt on whether is it horizontal or vertical
thank for you reply
Note that thrust and drag are partly horizontal and partly vertical.
You must use sine and cosine to get their horizontal and vertical components.
The vertical component of thrust will be 9000 kN *sin(10).
Recommend you start with the horizontal part; looks like it will be easy to solve for the drag.
