Vertical Spring Oscillation Frequency
The discussion centers on calculating the oscillation frequency of a mass-spring system where a block is dropped onto a spring. The relevant formula for frequency is f = (1/2π)√(k/m), where k is the spring constant and m is the mass. Participants explored using conservation of energy to relate the spring constant k to the amplitude A and the height h from which the block was dropped. The final calculated frequency, after resolving the equations, was approximately 0.15989 Hz.
  • Understanding of mass-spring systems and oscillation principles
  • Familiarity with conservation of energy concepts
  • Knowledge of quadratic equations and their applications
  • Basic proficiency in algebra and manipulation of equations
  • Study the derivation of the mass-spring frequency formula f = (1/2π)√(k/m)
  • Learn about energy conservation in mechanical systems, specifically for oscillating bodies
  • Practice solving quadratic equations in the context of physics problems
  • Explore the relationship between amplitude, spring constant, and frequency in oscillatory motion
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for examples of mass-spring systems in action.
jzwiep
A spring is standing upright on a table with its bottom end fastened to the table. A block is dropped from a height 2.8 cm above the top of the spring. The block sticks to the top end of the spring and then oscillates with an amplitude of 12 cm.
What is the oscillation frequency? (Hz)
Don't know.
The only thing I can think of is it looks like a conservation of energy question, but I don't know where to start.
Can anyone give me a nudge in the right direction?
What's the equation for the frequency of a mass-spring system? Hint: it includes m and k. You need to figure out k based on the amplitude.
Okay, so I found the formula relating k to f:
f=(1/2pi)sqrt(k/m)
I haven't been able to find anything that would relate k to A without any additional variables (like the vmax formula in terms of k, m, and A).
Whatever it is has to cancel out the mass in the f formula, but is there more info in the question that I'm just not getting? Would the fact that it is released 2.8cm above the top of the spring give me another piece of information?
Thanks.
Alright, I tried using conservation of energy.
U=mg(A+dL+h)
Where A is the amplitude, dL is the spring compression to equilibrium, and h is the height the height the mass was dropped above the spring.
Along with:
Fg=Fs
mg=k*dL
and
f=(1/2pi)sqrt(k/m)Am I at least on the right track? I can't seem to find an answer, so some help would be much appreciated.
U=mg(A+dL+h)
You're on the right track. Where's your conservation of energy equation?
Etotal=Us=Up
1/2kA^2=mg(A+dL+h)
I rearrange with equilibrium forces equation to get:
6k^2-145mk-96m^2=0
Then using the quadratic equation to yield:
(145m +/- 220.62m)/144
So k=2.539m
Then I substituted in for k in
f=(1/2pi)sqrt(k/m)
f=(1/2pi)sqrt(2.539)
=3.9883Hz
=4.0Hz
Which wasn't the right answer.
jzwiep said:
Etotal=Us=Up
1/2kA^2=mg(A+dL+h)
Careful here. The spring is compressed from its original uncompressed position, not just from the new equilibrium position.
jzwiep said:
Etotal=Us=Up
1/2k(A+dL)^2=mg(A+dL+h)
72k^2-145mk-48m^2=0
(145m +/- 186.68m)/144
So k=2.303m
f=(1/2pi)sqrt(k/m)
f=(1/2pi)sqrt(2.303)
=2.38Hz
Is this now the correct formula? I only have a few attempts left so I didn't want to check if the answer was right.
Yes, that's the correct formula. I haven't checked your calculation, but I'd be happy to do so later when I have some time. (If you can wait a few hours; I'll be off line for a bit.)
If you wouldn't mind doing so that'd be great. Thanks.
I get a different answer.
jzwiep said:
Etotal=Us=Up
So far, so good.
72k^2-145mk-48m^2=0
Show how you got this one.
dL=mg/k
1/2k(A+mg/k)^{2}=mg(A+mg/k+h)
1/2kA^{2} + 1/2m^{2}g^{2}/k = mg(A+h) + m^{2}g^{2}/k
1/2k^{2}A^{2}- kmg(A+h)-1/2m^{2}g^{2}=0
jzwiep said:
dL=mg/k
Looks good.
Ah... looks like you made an error when you expanded (A+mg/k)2.
(a + b)2 ≠ a2 + b2
Ah, that was silly of me
jzwiep said:
dL=mg/k
1/2kA^{2} + Amg + 1/2m^{2}g^{2}/k = mg(A+h) + m^{2}g^{2}/k
1/2k^{2}A^{2}- kmgh-1/2m^{2}g^{2}=0
So changing that gives me:
72k^{2} - 27.44mk - 48m^{2}
Which works out to:
k=1.02899m
Giving me a:
f=http://www.wolframalpha.com/input/?i=sqrt(1.02899)/(2pi)"
Is that correct?
I'd say you're off by a factor of 10, so double-check your arithmetic.
Okay it looks like I did the quadratic wrong,
(27.44m + 117.895m)/144
k=1.00927m
Which gives f=0.15989Hz
But that's not a factor of 10 off. I double checked my algebra for:
1/2k^{2}A^{2} - kmgh-1/2m^{2}g^{2} =0
And it looks right. Do you know if I'm getting my error from here? or from my quadratic?
That equation looks fine. You're making an error when you solve the quadratic.
Alright, thanks for the help.
  • · Replies 24 ·
