Voltage across a potentiometer?
43 replies · 39K views · last reply
This expands to
$$\frac{3}{9}=\frac{50-50x}{100x-100x^2+50x+50-50x}$$
Which then matches my original answer further up in this thread. Funny how something so simple was overlooked on my part.
Could you explain a little further how you managed to get to that stage in your last post. Always keen to learn new methods.
Regards
Electest
I mentioned it in the post. Beginning with the full "complex fraction" of post 22, I divided numerator and denominator by the numerator expression. Naturally that leaves a "1" for the numerator and "<mess> + 1" for the denominator.
gneill said:
As a suggestion, since R2 is in parallel with R3 and you'll need to expand that twice, why not make R2 = 10x and R1 = 10(1-x)? That will cut down the amount of work you need to do when you expand the parallel combinations. It just means that x will be the "distance" from the bottom end of the potentiometer rather than the top end.
Hi, I've just tried this method and couldn't get it to work, can you show me this other method, when i tried i canceled it down to 2x2 -x -1 =0
not sure where I made my mistake, I got the other way to work fine, can't see why it didn't work swapping them round
also, wouldn't it work if the slider was at the bottom, which would put the resistors in series, as 5/(5+10) is still a third which is what we want
You'll have to show us your workings, not just your conclusion, in order for us to see where your attempt has gone awry.
If the slider is at the bottom of the pot then it will be connected to the 0 V reference node and the output will be 0 V, not the required 3 V. Another way to look at it is that when the slider is at the very bottom of the POT the 5k load resistor will be shorted out.
Circuit schematic with a 9 V source across two series resistors: a 10 kΩ resistor and a 5 kΩ resistor, with a wire from their junction back to the 0 V reference node at the bottom.
  • Circuit schematic: 9 V supply across a 10 kΩ resistor in series with a 5 kΩ resistor, with the junction between them joined to a 0 V reference node.
my working was pretty much the same as the others, just swapping the (1-x)'s and x's around
1/3 = [5*10x/(10x+5)] / [(5*10x/(10x+5) + 10(1-x)]
got this to 1/3 = [50x]/ [5*10x + 10(1-x)(10x+5)]
then to 1/3 = [x]/[-2x2+2x+1] divided through by 50
Something went wrong between your first and second lines. While the first line expression is fine and leads to the correct solution for x, the second line does not. So, check your algebra steps in between the two.
yeah, sussed it, 3x - 2x does not equal -x
thanks for the help
Hi, I am also struggling with this one if anyone can point me in the right direction.
This is where I am with it:
3/9 = 10χ5/10χ + 5
10(1-χ) + 10χ5/10χ + 5
I have tried to simplify further:
50χ/10χ+5
10χ-10 + 50χ/10χ+5
5/5
10χ-10 + 5/5
10χ-9
I can work out χ but feel that I am not doing this right and would appreciate and help or input.
Thanks for your time :smile:
3/9 = 10χ5/10χ + 5
50χ/10χ+5
10χ-10 + 50χ/10χ+5
5/5
10χ-10 + 5/5
10χ-9
Your problems seem to be with the algebra rather than the physics. For example in your second line, in expanding the 10(1 - x) term in the denominator you wrote 10x - 10. You've negated the signs.
Work through your algebra carefully. Pick a "test" value for x that you can plug in after each "simplification" to check that the overall expression hasn't changed value (not a 100% foolproof test, but it will usually raise the "I did something boneheaded there in that step" flag).
By the way, you may want to investigate the LaTex syntax that's available for rendering math formulas. You can avoid having space compression and proportional fonts mucking up the formatting of your equations by using LaTex. Check out this quick LaTex overview post for more information.
Hi guys,
I have been searching for a way to solve the equation past here and came up short ( no idea why the image is sideways sorry). Is there a rule I'm forgetting about to simplify the last part to determine x?
Handwritten working on squared graph paper, rotated sideways: a voltage divider equation with resistors R1, R2 and R3, algebra in x involving 50(1-x) and 10x terms, and a small circuit sketch with 10 kΩ and 5 kΩ labelled.
Check your expansions of ##10(1 - x) + 5##. There should be a ##10 x## in the result.
There's no secret method, it's just a matter of slogging through the expansions and cancellations, cross multiplications and so forth, to arrive at a quadratic equation in x.
After cross multiplying and simplifying the equation and then using the quadratic formula to get 2 values for x I've ended up with 2 values that use imaginary numbers, clearly this is not correct and I've gone wrong somewhere above. I'm pretty sure I've cross multiplied incorrectly but not obviously not 100% sure at what stage I've messed up. Any help would would be greatly appreciated thanks.
Handwritten working on graph paper: a potentiometer circuit diagram with a 9 V source and resistors R1, R2 and R3, beside a voltage divider equation Vp = V3 times a fraction, followed by substituted and simplified algebra.
Handwritten algebra working on lined paper: 3 times (50 - 500x)/(15 - 10x) = 10x + (50 - 50x)/(15 - 10x), rearranged step by step to -1000x^2 + 250x - 100 = 0, then the quadratic formula applied with a = -1000, b = 250, c = -100.
