- 30,548
- 7,530
That's what Potential Difference is all about. Although, with an attractive force, the Energy is defined as Negative. For a wire made of a highly conductive metal the PD across the length will be tiny.
mean that conventionally the energy flows from the plus to the minus?sophiecentaur said:the Energy is defined as Negative
What do you mean for "across the length" ?For a wire made of a highly conductive metal the PD across the length will be tiny.
scientifico said:mean that conventionally the energy flows from the plus to the minus?
Yes, I have to agree with you there. It may be true bit it isn't really relevant.Windadct said:IMHO - the "Negative Energy" term is really just confusing this issue. Energy moves (converted) from one system to another, a positive or negative reference only applies to the point of observation or the difference in two or more states ( top of the waterfall vs bottom of the waterfall, battery before the current flows vs after the current flows) They have less energy, but they do not negative energy.
scientifico said:The force that act on electrons is provided by the positive charges, so teorically if i connect a piece of wire only to the positive pole, is there a possibility that some electrons of the wire go to the +?
Thank you!
