Voltage Null Points of a Mechanical Meter Bridge
The discussion centers on the concept of voltage null points in a Mechanical Meter Bridge, specifically addressing the conditions under which point D can be considered a null point compared to point B. The user argues that if the resistance of segment AD is less than that of segment AB, then point D should exhibit a higher potential than point B, resulting in current flow from D to B. However, the textbook states that when the jockey is connected to the left of D, no current flows through wire B, indicating a misunderstanding of the null point conditions. This discrepancy highlights the importance of accurately assessing resistance and potential differences in electrical circuits.
  • Understanding of electrical resistance and potential difference
  • Familiarity with the principles of a Mechanical Meter Bridge
  • Knowledge of Ohm's Law and its application in circuit analysis
  • Basic concepts of current flow in electrical circuits
  • Study the principles of Mechanical Meter Bridges in detail
  • Review Ohm's Law and its implications for circuit behavior
  • Explore the concept of null points in electrical measurement
  • Investigate common misconceptions in electrical circuit analysis
Students and educators in physics or electrical engineering, particularly those studying circuit analysis and measurement techniques using Mechanical Meter Bridges.
Shreya
The answers of this question is mentioned to be A & C. My question is why isn't B true?
Please be kind to help
My reasoning is that the wire has a resistance/unit length. The resistance of AD must equal that of AB for D to be called a null point. If we move jockey to the left, the resistance of AD decreases, thereby decreasing the potential drop across it. This means that the V of D is more than that of B causing a current to flow from D to B. So according to me B should be an answer, while the textbook says.
when jockey is connect to the left of D no current in the wire B. that is why its wrong
I cannot understand why it is so. Could you please explain? According to my reasoning the resistance of AD< that of AB. Therefore, the V drop across AD is lower making D at a higher potential than B, causing a current to flow from D to B.
  • · Replies 18 ·
