Voltage required for penetration of an unknown element
The discussion focuses on calculating the voltage required for a proton to penetrate an unknown element with a nucleus charge of 14.00 e and a radius of approximately 3.60×10-15 m. The correct approach involves using the formula V = kQ/r, where k is Coulomb's constant (8.99e9 N m2/C2), Q is the charge of the nucleus, and r is the radius. The final voltage calculated is 6.79e6 V, achieved by considering only the charge acting on the proton, not the proton's own charge.
  • Coulomb's Law and its applications
  • Understanding of electric potential and voltage
  • Basic knowledge of point charges and their interactions
  • Familiarity with fundamental physics equations, specifically V = kQ/r
  • Study the concept of electric potential energy in electrostatics
  • Learn about the integration of forces in electric fields
  • Explore the implications of charge interactions in particle physics
  • Investigate advanced topics in Coulomb's Law applications
Students in physics, particularly those studying electrostatics, as well as educators and anyone interested in the principles of charge interactions and voltage calculations in particle penetration scenarios.
grantaere
An unknown element has a nucleus with charge 14.00 e and a radius of about 3.60×10-15 m. How much voltage must be used to accelerate a proton (radius 1.20×10-15 m) so that is has sufficient energy to just penetrate the unknown element?
Assume that the potential is that for point charges.
V = kQ/r
I tried calculating the two potential differences caused by the incoming proton and the positively charged atom, then adding them separately, but it seems that this isn't the right answer/ right approach.
V = (8.99e9*(14*(1.6e-19))/3.6e-15) + (8.99e9(1.6e-19)/1.2e-15) = 6.79e6 V
Any pointers would be very much appreciated!
You are looking for the amount of energy (work) to bring two charges into contact. What is the force between two charges?
So then I should use F=fqQ/r^2 to find the force between the two charges when they meet? I did that (and got 6.71E-13N) -- so then I can find the acceleration, but I'm still not sure how value this would be used to calculate voltage?
Just wanted to know if you were familiar with the general Coulomb repulsion/attraction. The problem statement has apparently done the integration for the work, but omitted one of the charges, perhaps to give you a potential (rather than work) in terms of volts per unit charge. Hint enough?
Oh, I got the answer now. I forgot that the calculation for potential difference only involves the charge acting on the proton, and doesn't involve the charge of the proton itself. Thanks for your help!
  • · Replies 17 ·
15K
