Volume of a function around an axis
The discussion focuses on finding the volume of the solid formed by rotating the function f(x) = ½ x² + 2 around the line x = 3, bounded by the region between x = 0 and x = 4. Initially, there was confusion regarding the axis of rotation and the boundaries, but it was clarified that the function is bounded by y = 0 and y = 4. The user correctly transformed the function into terms of y for the volume calculation, establishing the radius for the area formula. They derived the volume expression as π ∫ (sqrt(2x-2) - 6sqrt(2x-2) - 13) dy from y = 0 to y = 4. However, discrepancies arose when comparing volume results using different bounds, leading to uncertainty about the consistency of the calculations.
BFPerkins
Given this problem:
Find the volume and describe the shape of the object formed by the function f(x) = ½ x²+2 when the function is rotated around the x =3 axis and bounded by th region between the x = 0 and x = 4.
I am not sure if I am thihnking about this correctly. I know in order to find the volume, I must use the formula 2π ∫Pxhx dx between x = 0 and x = 4. However, since it is rotatated around the x= 3 axis, do I use that as my starting point. Meaning, do I make 3 equal to zero and make the x boundaries as the difference from 3 to their points?
The axis of rotation is inside the region to be rotated so that the solid would intersect itself, did you copy the problem down right?
Sorry! Never mind the question. I was looking at the problem wrong. The function is bounded by y = 0 and y = 4, not x. Now it is a piece of cake!
I'm back and I've carefully checked to make sure I am reading it correctly.
First I set function in terms of y because of its rotation around the verticle axis, which gives me
y = sqrt(2x-2) Then I subtracted 3 because it revolves around x = 3. This is my radius, so I square it to get my area ( and multiply by Pi)
which gives [sqrt(2x-2 - 3]^ 2 = 2x - 6sqrt(2x-2) - 13
So my volume is π ∫ sqrt(2x-2) - 6sqrt(2x-2) - 13 dy from y = 0 to y = 4.
I get [ x² -13x - 4sqrt(2x-2)^(3/2)
Since the lowest point of this function is 2 on ther y axis, the volume should be the same whether I use the bounds of 2 to 4, or 0 to 4, but I keep gwetting differeent results for those two limits.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
