Volume of a Solid by Revolution
7 replies · 5K views · last reply
Sidew
Hi, the next problem I thought it was easy...and I really think it is, but I haven't come with the right answer :S. I compare the answer in an internet page of problems and all it says is "wrong"...
The problem is the following:
Find the volume of the solid obtained by rotating the region bounded by
y=8*x+32, y=0 about the y-axis.
I made the sketh in Maple:
http://img109.imageshack.us/img109/5669/solidvolumexi5.th.jpg
Then I solve for x:
x=(y/8)-4
and wrote the Integral with respect to y, and limits from 0 to 32 (where the function y=8x+32 intersects the y-axis).
Integral of Pi*f(x)^2, from y=0 to y=32, it should give me the volume, isn't it?
http://img164.imageshack.us/img164/98/equationie6.th.jpg
My answer: 512/3 * Pi= 536.1651462
But the internet page says I'm wrong but I don't know why :S
Any help is welcome, Thanks in advance!
Your answer looks right. I'd say the super trustworthy internet is wrong ;). (Disclaimer: I'm getting back into calc after a year of none, but still I'm quite sure you're correct).
Possibly: Integration of Pi * (8x + 32)^2. -4 (lower limit) and 0 (upper limit)
Thanks to all of you for your answers.
AngeloG, I already tried what you suggest and I came with the answer:
4289.321169 which is wrong as well.
And because the region should be rotated about the Y-Axis and not about the X-axis, that's why I solved the equation for X, in order to have only Y's so I could integrate with respect to dy, then my limits are Y=0 and Y=32.
I hope I didn't understand you another thing, maybe "4289.321169" wasn't what you get, so I would like to know your answer.
Thx again^^, cheers!
Err, forgot to say change the x's for y's and the y's for x's.
8x + 32 is basically the same as 8y + 32. One is just tilted on it's side, which is the y. Then you can integrate from -4 to 0, then rotate it around y-axis tilted.
(4096 / 3) * Pi, which is ~4289.3
However, I am wrong =). I was just doing the other half, considering your half was wrong. There's only two ways to do this and if both provide the wrong answer. Might be the page.
y= 8x+ 32 is a straight line with intercepts (0, 32) and (-4,0), rotating around the y-axis gives a cone with height 32 and radius 4. you can check the volume by using the standard formula for volume of a cone: [itex]V= \frac{1}{3}\pi r^2h[/itex].
Thx again for all your answers^^, I didnt know there will be so many options or ways to solve the problem.
AngeloG, thanks for your reply.
HallsofIvy, I tried that :O, and I got: 536.1651462, but the page says its wrong -.-, so now I'm almost sure that is the webpage.
cheers!
It might be a significant digits problem. Did you try just "536"?
