What is the volume of a tetrahedron formed by given points?
The discussion revolves around calculating the volume of a tetrahedron formed by four given points in 3D space. The initial approach involves using vector cross products to determine the area of triangular slices and integrating to find the volume, but the user encounters difficulties with the integration process. Alternative methods are proposed, including finding the area of the base and the height through projections, which could simplify the calculation. The conversation highlights the importance of correctly parameterizing the vectors and understanding the relationship between the variables involved in the integration. Ultimately, the user expresses optimism about resolving the issues with the guidance received.
mikfig
Let points P1: (1, 3, -1), P2: (2, 1, 4), P3: (1, 3, 7), P4: (5, 0, 2)...form the vertices of a tetrahedron. Find the volume of the tetrahedron.
V = 1/3 ah
A = area of base
h = height of tetrahedron
I wanted to solve this using the fact that | u x v | = area of a parallelogram formed by the vectors u and v. So I designated P1 as the "top vertex" and the other three as the vertices forming the "base" of the tetrahedron.
Then I figured I would divide the tetrahedron into "triangle slices" whose area was | u x v| / 2 while u and v where the two vectors forming this slice.
Then:
u = (P3 +t(P1 - P3)) - (P2 +t(P1 - P2))
v = (P4 +t(P1 - P3)) - (P2 +t(P1 - P2))
And I integrated | u x v | / 2 from t = 0 to t = 1. After simplifying | u x v | / 2 into an expression in terms of t, I get:
1/2 sqrt(75t^4 - 290t^3 +450t^2-290t + 75)
So when I integrated 1/2 sqrt(75t^4 - 290t^3 +450t^2-290t + 75) dt from 0 to 1, I got approximately 2.25426. Note: I had to integrate numerically as Mathematica couldn't integrate analytically.
The real answer is 20/3 or 6.66667. I looked at this and saw that if you multiply my answer by 3 then you get 6.76278, which is within 0.0961158 of the real answer.
I'm not sure if that means I am missing a constant term in my integral, but that 1/3 in the tetrahedron volume equation caught my eye as I didn't understand the reason for it when I read a proof on a website I can't remember.
Anyways, now I am thinking that I overlooked the differential and that dt should have been dy in the integral, and I would have to then somehow express dt in terms of dy. But I haven't looked at that part yet. I think I will take a look at it tomorrow, after my AP Macroecon test.
Thanks a lot,
mikfig
do you have to integrate? how about finding the area of the base then a vector perp to the base, then find the height by the projection onto that vector...
also as another idea, you could parameterise in terms of the vetical height, then the area of a slice will vary by a factor of 1 to 0, as the height goes form the base to the peak, that should be pretty easy to integrate as it will just be t...
lanedance said:
do you have to integrate? how about finding teh are of the base then a vector perp to the base, then find the height by the projection onto that vector...
also as another idea, you could parameterise in terms of the vetical height, then the area of a slice will vary by a factro of 1 to 0, as the height goes form the base to the peak, that should be pretty easy to integrate as it will just be t...
No, I don't have to integrate. I just wanted to solve it this way because its more challenging than just plugging in height and base area to the tetrahedron volume equation.
As far as parameterising in terms of vertical height, that is exactly the approach that I am taking. I just didn't know how to put into words what the t variable represents. Like I said though, I think the problem I'm having is what to put for the differential. Because I don't think it makes sense for volume of a "triangular slice" to just be (| u x v | / 2) dt.
So I think I just have to ponder on exactly what should go after the cross product term.
Thanks,
mikfig
why not?
| u x v | represents the area of the parollelogram given by u & v, and dt represents an infinitesimal slice
in this you should parmetrise t along a line form base to peak of the tetrahedron. Depending on how you do this you will need to include a scale factor:
- if you paramterise the line, and t varies from 0 to 1, you need to scale by the height of the tetrahedron
- if you paramterise the line, and t varies from 0 to h, the scale factor will be 1 as t is direct representation of length (probably teh easiest way)
the way to do that explicitly, is to first write the volume element, dV = | u x v |ds, where ds is an intesimal length element, then find ds in terms of dt in you line paramterisation & integrate over t, by substituting into your equation
also note that as t varies from 0 to 1, along t lengths are proportional to t, so the area of a slice A(t) is proportional to t^2. Hence when you integrate you get the factor of 1/3.
i've had a look at you original post and think you may have made a mistake early on. Note the way you paramterise u & v, the direction of the vectors should not change, only the length. This means you should be able to write it as
\textbf{u}(t) = \textbf{u}_0 c t
\textbf{v}(t) = \textbf{v}_0 c t
where c is some scale factor... and \textbf{u}_0, \textbf{v}_0 are the orginal base vectors
then when you take the cross product, you shold get
|\textbf{u}(t) \times \textbf{v}(t)| = |\textbf{u}_0 \times \textbf{v}_0| | c^2 t^2|
so it should just be an integral of t^2
Sorry it has taken me so long to respond, I was merely thinking over your responses.
I don't understand here how you say "along t", as t isn't a vector but rather a scalar.
As you can see from the picture I attached, I don't think that u and v can be described by any base vectors. Because as you can see, any two combinations of u and v for two different values of t are parallel. And if they are parallel then they are said to be linearly independent and thus they can't be described by each other.
Thanks,
mikfig
correct that t is a scalar, but changing the paramater t to t+dt will move you along the line and there will be a corresponding length in space ds correspodning to the change dt
Thanks,
mikfig
if you parametrise along a line perpindicular to the base, then a volume slice wil be
dV = A(t) ds = |u(t) X v(t) |/2 ds
in you diagram the direction of u does not change, only its length. Same for v.
i'm not sure what you're trying to say here... parallel vetctors are linearly dependent
damn, i just realized what a stupid statement that was :(. ok you now i see, since they're parallel then the direction is always the same by definition :D
I found that |\textbf{u}(t) \times \textbf{v}(t)| = 5\sqrt{3}t^2 - 10\sqrt{3}t + 5\sqrt{3}:
\textbf{P}_1: (1, 3, -1), \textbf{P}_2: (2, 1, 4), \textbf{P}_3: (1, 3, 7), \textbf{P}_4: (5, 0, 2)
\textbf{u}_0 = \textbf{P}_3 - \textbf{P}_2
\textbf{u}(t) = (\textbf{P}_3 + t(\textbf{P}_1 - \textbf{P}_3)) - (\textbf{P}_2 + t(\textbf{P}_1 - \textbf{P}_2))
\textbf{u}(t) = (1 - t)\textbf{P}_3 - (1 - t)\textbf{P}_2
\textbf{u}(t) = (1 - t)\textbf{u}_0
\textbf{v}_0 = \textbf{P}_4 - \textbf{P}_2
\textbf{v}(t) = (\textbf{P}_4 + t(\textbf{P}_1 - \textbf{P}_4)) - (\textbf{P}_2 + t(\textbf{P}_1 - \textbf{P}_2))
\textbf{v}(t) = (1 - t)\textbf{P}_4 - (1 - t)\textbf{P}_2
\textbf{v}(t) = (1 - t)\textbf{v}_0
|\textbf{u}(t) \times \textbf{v}(t)| = |(1 - t)\textbf{u}_0 \times (1 - t)\textbf{v}_0|
|\textbf{u}(t) \times \textbf{v}(t)| = (1 - t)^2|\textbf{u}_0 \times \textbf{v}_0|
|\textbf{u}(t) \times \textbf{v}(t)| = 5\sqrt{3}(1 - t)^2
Now I just have to figure out what how to express ds in terms of dt.
Thanks,
mikfig
yeah sorry, i think i may have confused things as well - the "line" doesn't enter specfically into the integral, but is how i always think of parameterising the problem, then slices are perp to the line
say you let t vary from 0 to 1, then just let s = ht, where h is the height of the tetrahedron - this will give the correct physical dimensions & so volume
Cool, I think that should work perfectly.
Thanks for all the help :D,
mikfig
  • · Replies 178 ·
9K
10K
