Volume of ellipse rotated about x = -2 using shell method
2 replies · 3K views
Pull and Twist
The question is...
Take-Home Problem said:
Find the volume of the solid obtained by rotating the ellipse $${x}^{2}+4{y}^{2}=4$$ about $$x=-2$$ using the Shell Method. *Table of Integrals is not allowed for integration.
So of course I rearrange my ellipse formula to get $$y=\pm\sqrt{1-\frac{{x}^{2}}{4}}$$
Then I calculate my radius as $$x-(-2)=r \implies x+2=r$$
I know the formula for finding volume with the Shell Method is $$V=\int_{a}^{b}2\pi x\cdot f(x) \,dx$$
To make it easier I decide to just find the volume of the top half and times my equation by two. Having graphed the equation I know I need to integrate between $$-2\le x\le2$$
So I then have...
$$2\int_{-2}^{2} 2\pi(x+2)(\sqrt{1-\frac{{x}^{2}}{4}})\,dx$$
$$4\pi\left\{\int_{-2}^{2} x(\sqrt{1-\frac{{x}^{2}}{4}})\,dx + \int_{-2}^{2} 2(\sqrt{1-\frac{{x}^{2}}{4}})\,dx\right\}$$
$$4\pi\left\{\int_{-2}^{2} x(\sqrt{1-\frac{{x}^{2}}{4}})\,dx + 2\int_{-2}^{2}(\sqrt{1-\frac{{x}^{2}}{4}})\,dx\right\}$$
Using $$u=1-\frac{{x}^{4}}{4}$$ substitution for the first integral I get...
$$4\pi\left\{-\frac{4}{3}\left[{\left(1-\frac{{x}^{2}}{4}\right)}^{\frac{3}{2}}\right]_{-2}^{2} + 2\int_{-2}^{2}(\sqrt{1-\frac{{x}^{2}}{4}})\,dx\right\}$$
Am I taking the right approach?? If so... how do I integrate the second integral w/o using a table of integrals?? Would this problem be easier utilizing the disk/washer method?
I need me some help. Thanks.
First off, we know this is a torus, and so the volume will be:
$$V=2\pi(2)\pi(2)(1)=8\pi^2$$
We can use this to check our answer. So to set this problem up, I would begin with the volume of an arbitrary shell:
$$dV=2\pi rh\,dx$$
where:
$$r=x+2$$
$$h=2y=2\frac{\sqrt{4-x^2}}{2}=\sqrt{4-x^2}$$
And so we find:
$$V=2\pi\int_{-2}^2(x+2)\sqrt{4-x^2}\,dx=2\pi\left(\int_{-2}^2 x\sqrt{4-x^2}\,dx+2\int_{-2}^2\sqrt{4-x^2}\,dx\right)$$
For the first integral, I would use the odd-function rule (it is zero), and for the second integral I would use the even function rule to get:
$$V=8\pi\int_{0}^2\sqrt{4-x^2}\,dx$$
Next, I would use the substitution:
$$x=2\sin(\theta)\,\therefore\,dx=2\cos(\theta)$$
Or you could argue that the remaining integral represents the area of a quarter circle having radius 2. :D
Can you proceed?
Awesome, that worked! I didn't even think about substituting $$x=2\sin\left({\theta}\right)$$. I've been spoiled by using my Table of Integrals.
That left me with $${\cos}^{2}\left({\theta}\right)$$ after utilizing my trig identities and combining terms.
Replaced that using the half angle formula... substituted $$u=2\theta $$ $$\frac{du}{2}=dx$$ and integrated the result.
$$8\pi\left[u+\sin\left({u}\right)\right]_{0}^{\pi}$$
Which gives you $$8\pi\left[\pi\right]$$ or $$8{\pi}^{2}$$
