Volume of Solids with Known Cross Sections (Calculus AB)
This discussion focuses on calculating the volume of solids generated by revolving the area bounded by the equations y = 6 - 2x - x² and y = x + 6 around the x-axis and the line y = 3. The user initially attempted to set up the integrals but encountered errors in both the limits of integration and the coefficients of the polynomial terms. The correct volume for the revolution around the x-axis is 243π/5, while the volume around y = 3 is 108π/5. Key issues identified include the proper setup of the "top minus bottom" function and the correct application of the volume formula.
  • Understanding of integral calculus, specifically volume of revolution
  • Familiarity with polynomial functions and their intersections
  • Knowledge of the disk and washer methods for calculating volumes
  • Proficiency in LaTeX for mathematical expressions
  • Study the disk and washer methods for volume calculations in calculus
  • Learn how to find intersection points of polynomial functions
  • Practice setting up integrals for volumes of revolution around different axes
  • Explore LaTeX formatting for clear mathematical communication in forums
Students studying calculus, educators teaching volume of solids, and anyone seeking to improve their skills in setting up integrals for volume calculations.
Flaneuse
Can anyone help me with this calculus problem? I have tried it a couple of different ways, but keep getting various incorrect answers; I think my problem is probably in the setup.
I am trying to find the volume of the solid created by revolving the area bounded by these two equations
y = 6 - 2x - x^{2}
y = x + 6
around the x-axis, and around y = 3.
First, I found the intersection points of the two equations, which are at (-3,3) and (0,6)
For the revolution around the x-axis, I tried doing
\pi \int ^{0}_{-3}((6 - 2x - x[^2})^{2} - (x+6)^{2} )dx,
simplified to \pi \int ^{6}_{0}(-32x -13x^{2} +4x^{3} + x^{4} )dx ,
and got a final answer of -27\pi/5
The correct answer is 243\pi /5
For the revolution around y = 3, I got -3-x^{2} from subtracting the lower function, x + 6, from the top function, 6 - 2x - x^{2}, and then tried
\pi \int^{6}_{0}(6-(-3-x^{2}))^{2} dx, simplified to \pi^{6}_{0}\int (6+3x+x^{2} ) dx, and ended up with 29376\pi/5.<br /> <br /> The answer for this one is supposed to be 108\pi/5<br /> <br /> <br /> Again, I think my real problems are in the setup, probably with the &quot;top minus bottom&quot; part.<br /> <br /> <br /> <br /> Also, I am new to Physics Forum, and can&#039;t seem to get rid of how, in the second integral, my words ended up included in the integral. I would appreciate it if anyone could tell me how to fix/avoid that.<br /> <br /> Thanks!
Note: Fixed up some of your LaTeX by removing a lot of superfluous [ tex] tags.
y = 6 - 2x - x^{2}
y = x + 6
\pi \int ^{0}_{-3}((6 - 2x - x^2)^2 - (x+6)^2)dx
The first integral above was fine, but there are some mistakes in the second one. You switched the limits of integration. They should still be -3 and 0. Also, the coefficients of the x^4 and x^3 terms are right, but those for the x^2 and x terms are incorrect.
simplified to
Again, I think my real problems are in the setup, probably with the "top minus bottom" part.
Also, I am new to Physics Forum, and can't seem to get rid of how, in the second integral, my words ended up included in the integral. I would appreciate it if anyone could tell me how to fix/avoid that.
Thanks!
I'll take a look at the 2nd integral in a separate post.
For the second integral,
\Delta V = \pi (R^2 - r^2)\Delta x
The limits of integration are the same, namely x = -3 to x = 0. R = the y-value on the parabola - 3, and r = the y-value on the line - 3.
Hm, I don't know what I must have been thinking when I decided to start integrating from 0 to 6, especially when I had already started using -3 to 0 as well... I suppose I was particularly jumbled yesterday, or something of that sort.
Thanks so much for the help; goodness knows I needed it. May I ask though, how can I differentiate between [yes, a very bad choice of words; I mean when to use one as opposed to the other, not take the derivative of] when R(x)^2 - r(x)^2 is equal to (top equation minus line)^2 - (bottom equation - line)^2 and when it is equal to (top minus bottom)^2 - (line)^2?
R is the larger radius and r is the smaller radius. Both radii are as measured from the axis of rotation. If you have drawn a sketch, it should be pretty obvious.
Thanks!
  • · Replies 27 ·
  • · Replies 20 ·
