Volume of tetrahedron when you are given four planes
The volume of a tetrahedron bounded by the planes x+y+z-1=0, x-y-1=0, x-z-1=0, and z-2=0 is calculated using vector analysis. The vertices of the tetrahedron are identified as A(1,0,0), B(0,-1,2), C(3,2,2), and D(3,-4,2). The volume of the parallelepiped formed by vectors AB, AC, and AD is determined to be 4, leading to a tetrahedron volume of 2/3. The alternative method using the formula Volume=1/3*B*h is also discussed, where B represents the area of the base triangle and h is the height from the fourth vertex to the base plane.
  • Vector calculus, specifically operations involving vectors and cross products
  • Understanding of geometric planes and their equations
  • Knowledge of calculating volume using determinants
  • Familiarity with the concept of tetrahedron and its properties
  • Learn how to calculate the area of a triangle using vector cross products
  • Study the method for finding the height of a point from a plane
  • Explore the determinant method for calculating volumes of polyhedra
  • Investigate the application of the formula Volume=1/3*B*h in various geometric contexts
Students studying geometry, particularly those focusing on three-dimensional shapes, as well as educators teaching vector calculus and volume calculations in higher mathematics.
borovecm
I have to find volume of tetrahedron that is bounded between 4 planes.
Planes are
x+y+z-1=0
x-y-1=0
x-z-1=0
z-2=0
\vec{a}=\vec{AB}=(X2-X1)\vec{i}+(y2-y1)\vec{j}+(z2-z1)\vec{k}
\vec{b}=\vec{AC}=(X2-X1)\vec{i}+(y2-y1)\vec{j}+(z2-z1)\vec{k}
\vec{c}=\vec{AD}=(X2-X1)\vec{i}+(y2-y1)\vec{j}+(z2-z1)\vec{k}
V(parallelepiped)=\vec{a}\ast(\vec{b}\times\vec{c})
V(tetrahedron)=1/6*V(parallelepiped)
I found four points where planes meet. These are:
A(1,0,0)
B(0,-1,2)
C(3,2,2)
D(3,-4,2)
From that I made vectors AB, AC, AD and then I put that into \vec{a}\ast(\vec{b}\times\vec{c}) and got that volume of parallelepiped is 4. From there I got that volume of this tetrahedron is 2/3. Is this the correct and shortest way to get a solution? My teacher said that I can use formula V=B*v/3 but I don't know where to use it.
I can't tell you where you would use B= B*v/2 since you haven't said what B or v mean in that formula!
Sorry. That's Croatian notation. I think american would be Volume=1/3*B*h where B is area of the base and h is height of tetrahedron. I can calculate h from formula for distance between point where first three planes intersect and the fourth plane. I don't know how to calculate area of the base. Is it correct that volume of this tetrahedron is 2/3?
You can choose any 3 of the 4 vertices to be a triangular base. A quick way of finding the area is to construct vectors \vec{u} and \vec{v} from one of the vertices to the other two. Then the area of the base, the triangle, is B= (1/2)|\vec{u}\times\vec{v}|. The height of the distance from the fourth point to the plane defined by the first three points.
You can find out the volume by this formula but it is difficult to calculate the determinant of a 4*4 matrix
@borovcm Don't put tex tags around every expression. Type whatever equations would nicely fit on one line and put the tags around that.
  • · Replies 0 ·
  • · Replies 25 ·
