Volume, Stewart ed 5, ch 6.2 # 48
  • Thread starter Thread starter rocomath
    Volume
The discussion centers on calculating the volume of a frustum of a right circular cone using integration. The user correctly sets up the integral for volume, represented as V = π∫₀ʰ[(y(r-R)/h) + R]² dy, where h is the height, R is the lower base radius, and r is the top radius. An alternative method for verifying the volume involves subtracting the volume of a smaller cone from the larger cone, utilizing the self-similarity property of cones to establish a ratio between the dimensions. This approach provides a geometric verification of the integral result.
  • Understanding of calculus, specifically integration techniques
  • Familiarity with the geometric properties of cones and frustums
  • Knowledge of self-similarity in geometric figures
  • Ability to manipulate and solve algebraic equations
  • Study the derivation of the volume formula for a frustum of a cone
  • Learn about the application of self-similarity in geometric calculations
  • Explore integration techniques for calculating volumes of revolution
  • Investigate the properties and applications of conic sections in geometry
Students studying calculus, geometry enthusiasts, and professionals involved in mathematical modeling or engineering applications related to volume calculations.
rocomath
Check please :)
A frustum of a right circular cone with height h, lower base radius R, and top radius r.
I chose to lay it upright, revolving it wrt the y-axis.
I have coordinates B(R,0) & b(r,h), thus y=\frac{h}{r-R}(x-R) \rightarrow x=\frac{y(r-R)}{h}+R
V=\pi\int_0^h\left[\frac{y(r-R)}{h}+R\right]^2dy
Is my set up right? I can integrate it myself, no prob there.
Thanks!
Looks right to me. You could just integrate and check it by looking up the volume of a cone frustrum.
Another way of checking the volume of a frustum is that it is a cone minus a cone taken off the apex of the original cone. Since a cone is a self-similar figure, the ratio of the top radius of the frustum to the base radius tells you the ratio of the height of the cone to be removed to the height of the original cone. As the cone is a three-dimensional figure, the volume of the removed cone will have a ratio to the original cone which is the cube of the ratio of the removed height to the original cone's height. It sounds more complicated in words than what you have to do geometrically. (Self-similarity is a wonderful thing...)
This should give you another way to check your result.
  • · Replies 17 ·
