Understanding the Mechanics of Walking on an Inclined Plane
The discussion focuses on the mechanics of walking on an inclined plane, specifically the forces acting on a person, including weight, normal force, and friction. It is established that leaning forward relative to the inclined plane helps maintain stability by balancing torques around the center of mass (COM). When walking, the center of mass must remain in front of the point of contact with the ground to prevent unbalanced torques that could lead to instability. The participants confirm that a person's body should remain as vertically aligned as possible while walking uphill to ensure stability.
  • Understanding of basic physics concepts such as forces and torques
  • Familiarity with the concept of center of mass (COM)
  • Knowledge of inclined planes and their effects on motion
  • Basic principles of static and dynamic equilibrium
  • Study the principles of torque and equilibrium in physics
  • Learn about the biomechanics of walking and how body posture affects stability
  • Explore the effects of incline on human gait and balance
  • Investigate the role of friction in motion on inclined surfaces
This discussion is beneficial for physics students, biomechanics researchers, physical therapists, and anyone interested in understanding the dynamics of walking on inclined surfaces.
Vibhor
Hello ,
This is a question related to an everyday activity .
My thinking - The base of the inclined plane is along the x-axis and it makes an angle θ with positive x-axis .We are looking from the +z axis .
There will be three forces acting on the person . Weight , normal(perpendicular to the plane) and friction(upwards along the plane) .
If a man does not lean forward and remains along a perpendicular to the plane then there would be an anticlockwise torque from friction about the COM .This unbalanced torque would cause instability .
But if the person is leaning forward , the line of action of normal force will not pass through the COM .A clockwise torque from normal about the COM will get balanced by an anticlockwise torque from friction resulting in stability .
Is my understanding correct . If not , please give a correct explanation and help me understand this .
Thanks
The expression "lean forwards" is a bit ambiguous. It could mean ...
1) lean forward relative to the vertical/gravity
or
2) lean forward relative to a normal to the plane.
It appears you mean 2). In which case your description is correct.
If the man is standing still (eg not accelerating) then these three forces sum to zero in all directions. So the normal force and friction must sum to provide a force that is vertical to counter gravity. So yes the man can't stand perpendicular to the surface but he doesn't need to do anything more than stand vertically upright. Does standing vertically really count as "leaning forward"?
Walking actually involves "falling" and that also requires us to "lean forward" or at least it requires us to put our COM in front of our point of contact with the ground (the rear foot). So actually we lean forward slightly when walking on level ground.
Thank you for replying .
CWatters said:
It could mean ...
Is it possible to remain stable in this ?
My question is something similar to
https://www.quora.com/Why-do-we-lean-forward-while-climbing-up-a-hill
I don't quite understand the explanation of keeping feet in line with the center of gravity to achieve stability .
Is it that in the link above the axis of rotation is taken to be the feet whereas I considered axis about the Center of Mass/Center of gravity ?
Is it correct that for stability , while walking up an inclined plane a person's body remains close to being vertical so that the force due to gravity doesn't create an unbalanced torque about the feet ?
I don't think the reply at that link is very clear. I think what they mean is you need to keep your centre of mass between your feet as below...
Thanks for the nice picture :)
How does that help in achieving stability ?
Is it that for stability , while walking up an inclined plane a person's body remains close to being vertical so that the force due to gravity doesn't create an unbalanced torque about the feet ?
You explained it in #1. If the COM is outside of your feet as per the right-hand drawing then a clockwise torque is created that pulls you over.
OK.
In simple words , while walking up an inclined plane a person's body remains as vertically aligned as possible .
Is this correct ?
It's not super critical. Read up on the process of walking, it involves falling forwards.
  • · Replies 41 ·
  • · Replies 37 ·
