Water gun problem, pump stroke -> pressure
The discussion revolves around the relationship between the stroke length of a hand pump, the diameter of the pump pipe, and the pressure generated in a water gun's pressure chamber. Participants explore theoretical and practical aspects of this relationship, including the application of the ideal gas law and Bernoulli's principle, while considering factors such as incompressibility of water and efficiency losses in the system.
  • Some participants propose that the volume of the pressure chamber is crucial for determining how much pressure can be built up with each pump stroke.
  • Others argue that the ideal gas law can be used to calculate the increase in pressure based on the mass of air added with each stroke, contingent on knowing the chamber volume.
  • A participant suggests that if the piston pumps air instead of water, the incompressibility of water means the pressure chamber's effective volume decreases with each stroke, affecting pressure calculations.
  • There is a discussion about using Boyle's Law to relate initial and final states of pressure and volume in the chamber.
  • One participant raises the possibility of calculating the velocity of water leaving the nozzle using Bernoulli's equation, while noting that losses in the system must be accounted for.
  • Another participant mentions the need to consider major and minor head losses in the system, suggesting modifications to Bernoulli's equation to include these losses.
  • Concerns are raised about the complexity of calculating the Reynolds number due to needing the velocity for its determination.
Participants express various viewpoints on the relationship between pump mechanics and pressure generation, with no consensus reached on specific calculations or methods. The discussion remains unresolved regarding the best approach to account for losses and accurately calculate the resulting pressure and velocity.
Limitations include assumptions about the ideal gas behavior, the incompressibility of water, and the efficiency of the pump system. The discussion also highlights the dependence on specific values and conditions that may not be universally applicable.
CollegeStudent
Hello all, I have a question about a water gun problem I'm working on.
The general question is...how can you associate the hand pump stroke length, and the diameter of the pipe the pump is inside, with how much pressure gets built up in the guns pressure chamber?
You can't without knowing the volume of the pressure chamber, obvious a larger pressure tank will tank more pumps to get up to a certain pressure.
Once you know tank volume then you can find the increase in tank pressure from each stroke from the ideal gas law.
https://en.wikipedia.org/wiki/Ideal_gas_law
Each stroke adds the mass of air (at atmospheric pressure & temp) found in the piston volume.
Alright, so let's see...lets take this animation for example: http://static.howstuffworks.com/flash/water-blaster-soaker.swf
****Only difference will be that originally the only water will be in the reservoir, nothing in the system****
Lets say the stroke length is 11 [in.] and the cylinder the piston is moving within has a diameter of 2 [in.]. Also we'll assume the volume of the pressure chamber is 250 [in^3]
*All general numbers*
The first out-stroke opens the first valve allowing water to fill that volume...the in-stroke would then input a mass of water equal to [itex]\pi \times (2 [in.])^2 \times 11 [in.] = 44 \pi [in.]^3 = 2265.17501 [g][/itex] directly into the pressure chamber? Am I saying that correctly?
Ha, obviously I would need to change the volume of the chamber...that's what I get for choosing random numbers!
Okay let's instead say the Volume of the Pressure Chamber is 5000 in^3 *again just choosing random numbers, as I know this is unrealistic for this application.
This is where I get a bit confused, the ideal gas law states [itex]P = \frac{mRT}{V}[/itex]
The original pressure in the chamber would be [itex]P = \frac{mRT}{V} = \frac{(\rho \times V)RT}{V}[/itex] so that would cancel out the Volume? Since I seem to be going in a circle, I'll just wait for clarification
Ok, I assumed the piston pumped air in, not water. In that case, seeing as water is incompressible the volume of the pressure chamber is effectively reduced by the volume of the piston with each stroke. The corresponding increase in chamber pressure will depend on the ratio of the chamber volume to the piston volume.
Got it, so to work with a general example... let's say the volume of the chamber is 5000in^3 originally when filled with just air.
The *cylindrical* piston has an 11 [in] stroke and we'll say a 2 [in] diameter...so the volume would be that same 2265 in^3
This volume would effectively be moved into the pressure chamber after each stroke.
So to find the pressure in the chamber after the first stroke,we are worried about the volume of air remaining in the tank? So (5000-2265) is the new volume of the tank? And we would use that to calculate the pressure?
For example *forgive me, on my phone* P = (mass of water * temp * R)/volume of air remaining in the tank?
This is probably incorrect as you stated it would depend on the ratio of volumes...so knowing the ratio is roughly 2.2...where do we go from there?
I appreciate your time by the way! Never knew a squirt gun could stump me so badly!
I think we can assume it's an isothermal process as I would expect the thin walls and the presence of the water would allow good heat transfer so the compressed air temp. does not rise above the ambient temp.
So we have two states, initial and final
PiVi =niRiTi
PfVf =nfRfTf
and the number of moles, gas constant and temperature are the same for both states so:
niRiTi = nfRfTf
and so
PiVi = PfVf
(which is Boyle's Law)
And solving for final pressure:
Pf = Pi (Vi / Vf)
PiVi =niRiTi
PfVf =nfRfTf
niRiTi = nfRfTf
and so
PiVi = PfVf
Pf = Pi (Vi / Vf)
Perfect, and that would be the pressure built up in the chamber after corresponding pumps
Now, if I wanted to find the velocity of water leaving the nozzle when the trigger is pushed...since I know the pressure in the chamber, I could set up a Bernoulli relation correct?
[itex]\frac{P_{nozzle}}{\rho} + \frac{V_{1}^2}{2} + gz_{1} = \frac{P_{chamber}}{\rho} + \frac{V_{2}^2}{2} + gz_{2}[/itex]
Where we know:
> V_2 is 0
> We can now find P_chamber using Boyles law above
> P_1 is atmospehric pressure
Am I correct in this regard?
Where we know:
> V_2 is 0
Yes, as a first order approximation.
Any real water gun has losses, the pump is not 100% efficient and there are major & minor losses throughout the system. At a random guess, I'd say only 50%-80% of the work done on the pump handle is converted to kinetic energy of the outgoing water.
Absolutely! And I do plan on having this losses accounted for!
Major head losses = [itex]h_{l} = f \frac{L}{D} \frac{V^2}{2}[/itex]
Where 'f' is the friction factor found via the Reynolds number and the roughness
Minor head losses = [itex]h_{ml} = k \frac{V^2}{2}[/itex] where k will depend on the bends in the system and other geometric factors etc
So I could always modify Bernoulli's and say:
[itex](\frac{P_{atm}}{\rho_{air}} + \frac{V_{1}^2}{2} + gz_{1}) - (\frac{P_{chamber}}{\rho_{water}} + \frac{V_{2}^2}{2} + gz_{2}) = f \frac{L}{D} \frac{V^2}{2} + \sum k \frac{V^2}{2}[/itex]
I can use my textbook to find:
>the roughness for certain materials
>friction factor (moody chart)
>minor loss coefficients for the various bends
So with all that, I believe I can solve for the true velocity of the water leaving the nozzle correct?
Hmm, although, the Reynolds number...
[itex]Re = \frac{VD}{v}[/itex]
since I need the velocity FOR the Reynolds number...maybe it isn't quite as easy as I am thinking?
Hey billy_joule, Sorry to bother you again, but any more insight on this?
While before, we could have calculated the velocity leaving the nozzle *ignoring losses*
Now, taking into account the losses, we have 2 more terms both requiring a velocity [itex]h_{l} = f \frac{L}{D} \frac{V^2 }{2}[/itex] and [itex]h_{ml} = k \frac{V^2}{2}[/itex]
I'm confused on how to find the friction factor here, as it is a function of Reynolds Number which involves the velocity.
At this point, should I guess a friction factor *assume the flow is turbulent* and iterate until I get a consistent value for V?
It looks like you're on the right track.
Yes, iteration is how I learned to solve these sorts of problems.
Perfect! Also, 1 LAST question that comes from the Boyle's Law relation we came up with earlier
[itex]P_{f} = P_{i}\frac{V_i}{V_f}[/itex]
Finding the initial pressure inside of the pressure chamber, using the ideal gas law, leads to [itex]P_{i} = \frac{mRT}{V}[/itex] Which, when replacing [itex]m = \rho V[/itex] leads to [itex]P_{i} = \rho R T[/itex]
I'm just confused here, as the volume of the tank should DEFINITELY play a factor in this shouldn't it?
Oh man...That was just a blonde moment...it took me actually calculating it out to see that it is just atmospheric pressure. That was fun haha!
  • · Replies 37 ·
  • · Replies 18 ·
