Calculating Water Pressure and Displacement in a Vertical Pipe
  • Thread starter Thread starter alibaba2
    Water
The discussion revolves around calculating the force required to press water from a container through a vertical pipe, specifically addressing the scenario of lifting water to a height of 30 feet. The subject area includes fluid mechanics and principles related to pressure and displacement.
  • Participants are attempting to determine the force needed to lift water, with some questioning the assumptions about the pipe's configuration and the volume of water involved. There are discussions about relevant principles such as energy, momentum, and work.
The discussion is ongoing, with participants exploring various principles that may apply to the problem. Some guidance has been offered regarding the calculation of force in relation to lifting a specific volume of water, but no consensus or resolution has been reached.
There is mention of missing notes and uncertainty about the correct formula to use, indicating constraints in accessing necessary information for solving the problem.
alibaba2
hi...
i have this question:
what would be the force in kilograms to press the entire volume of water from the container up the pipe at 30ft. ( some of the water will remain in the pipe of course).
see image:
img374.imageshack.us/my.php?image=graphic1qh8.jpg
BIG thank you
anybody??
anybody?
Hi alibaba2! :smile:
(I assume the pipe is open at the top, so the water just spills out and disappears.)
You need to calculate the force needed to lift a 2 ft cube of water to the top of a 30 foot pipe.
So the formula you should use is … ? :smile:
help
no idea whatsoever...i had the formula written down,but i can't access my notes from my current location...
any help tim?
10x
Well, what principle do you think would help … energy? … momentum? … work? … something else?
Hint: how much force is needed to raise a one-cubic-foot bucket of water a height of one foot? :smile:
  • · Replies 27 ·
  • · Replies 37 ·
