How Does Ambient Temperature Affect Aquarium Water Temperature?
  • Context: High School
  • Thread starter Thread starter Protek
    Water
The discussion centers on the relationship between ambient temperature and aquarium water temperature, emphasizing that in an enclosed system, the water temperature will closely match the surrounding air temperature given sufficient time to reach equilibrium. Participants clarify that while factors like evaporation and wet bulb temperature can influence readings, their overall impact is minimal. The consensus is that maintaining a desired water temperature requires careful control of the ambient conditions, as significant deviations from air temperature are challenging to achieve.
  • Understanding of thermodynamics in closed systems
  • Knowledge of evaporation and its effects on temperature
  • Familiarity with wet bulb temperature concepts
  • Basic principles of heat transfer
  • Research methods for controlling ambient temperature in enclosed spaces
  • Explore the principles of heat transfer in liquids
  • Learn about the effects of evaporation on temperature regulation
  • Investigate tools for measuring wet bulb temperature accurately
Aquarium hobbyists, environmental scientists, and anyone interested in maintaining optimal conditions for aquatic life in controlled environments.
Protek
Hello, I am in the process of trying to figure out the conditions required to heat an aquarium using the surrounding air. The first step is to figure out how to calculate the room temperature required to keep the aquarium at a desired temperature. I was drawn to this forum when I ran across another persons post on something similar but they wanted to know how to calculate natural bodies.
I'm wanting to know about an enclosed system, one body of water with adequate time to reach equilibrium with the atmosphere, what parameters would I need to control within that enclosed space to reach a desired temperature of the water and how would I calculate those parameters. Thank you for your time
Science news on Phys.org
It seems to me that you would have to work very hard to make the water any substantially different temperature than the ambient air. Perhaps I misunderstand the question
No I was just confused, I was thinking about evaporation and wet bulb and was in a rabbit hole. Now I understand that all other factors equal and unchanging the water will be the same temperature as the air. It's late and I didn't get a lot of sleep. Thank you though
There will be a small effect as you describe, but it is de minimus!
  • · Replies 16 ·
  • · Replies 66 ·
  • · Replies 19 ·
  • · Replies 109 ·
