First of all, the attenuation in common propagation in a medium is characterized by the decreasing amplitude with distance, not time. For example, imagine you are standing inside an attenuating medium certain distance away from the boundary surface with the air where a plane wave is coming from. If somehow you can measure the E field oscillation in time, you will observe that the amplitude of the oscillation at your place is constant with time. In other words, you should observe the wave as being still monochromatic as it was before entering the medium. What you did to the wave when you multiply it with ##e^{-kt}## is that you have changed its spectrum, which is not the case in reality.
Ok following your example the attenuated wave would look like ##e^{-kx}\sin{\omega t}##, now imagine again you stand in a fixed ##x## and measure the oscillation over time. It's still a sinusoidal function with the same frequency, and hence same period.
