Wave function in Infinite/Finite Potential Wells
The discussion revolves around determining the functional form of the wave function in various regions of an infinite/finite potential well, specifically focusing on the ground state. Participants are examining the implications of the Schrödinger equation in different potential regions and how these affect the wave function's behavior.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the wave function's behavior in regions with different potentials, questioning whether the solutions should be sinusoidal or exponential. There is exploration of the conditions under which each form is appropriate, particularly in relation to the energy of the particle compared to the potential.
The discussion is active, with participants offering insights into the mathematical forms of the wave function and the reasoning behind them. Some participants are clarifying the conditions that lead to different types of solutions, while others are reflecting on the implications of these conditions for the wave function's form.
Participants are considering the implications of the potential well setup, including the boundaries and the energy levels of the particle, which are critical for determining the wave function's characteristics. There is an emphasis on continuity conditions and normalization in the context of the wave function across different regions.
lee_sarah76
What is the functional form of the wave function in the ground state in the
five regions x<0, 0<x<a, a<x<b, b<x<L, and x>L?
I've attached the picture of the potential well as well here:
Schrödinger time independent equation
I understand that for x < 0 and x > L, ψ = 0 because there's no possibility of the particle being there.
And then between a and b: ψ = A*sin(kx) + B *cos(kx) where k = √(2mE)/(hbar)2
It's between 0 < x < a and b < x < L that I'm having issues. Can anyone point me in the right direction?
Thanks!
So remember how you get k in the first place in the region where the potential is 0:
[itex]\frac{-\hbar^2}{2m}\frac{∂^2\psi}{∂x^2}=E\psi[/itex]
The solution comes from 'guessing' [itex]ψ = A\sin(kx) + B\cos(kx)[/itex], and plugging this into the differential equation and algebraically solving for k.
Now consider the regions where [itex]V=U_0[/itex]
[itex]\frac{-\hbar^2}{2m}\frac{∂^2\psi}{∂x^2}+U_0\psi=E\psi[/itex]
[itex]\frac{-\hbar^2}{2m}\frac{∂^2\psi}{∂x^2}=(E-U_0)\psi[/itex]
Notice how this is the same equation as above, the only difference being [itex]E-U_0[/itex] instead of [itex]E[/itex].
At this point you just assume a similar solution for [itex]\psi[/itex] in the two regions with potential [itex]U_0[/itex] as you did with in the 0 potential region. Note however that the coefficients infront of the sines and cosines in each of the 3 regions are different in each region; to solve for each one continuity conditions, boundary values and normalizationmust be applied.
You should consider if the the ground state wavefunction will be sinusoidal or exponential in regions 0<x<a and b<x<L.
So I get that it will be the same as the function for a < x < b except that the constants in front of the sine/cosine will be different and k = √2m(E - Uo)/ (hbar)2?
Is that right?
Maybe, maybe not. Did you consider what TSny said? How did you conclude the wave function would sinusoidal and not exponential in that region?
The others have a point; the solutions you 'should' assume had the form
[itex]\psi(x)=Ce^{zx}+De^{-zx}[/itex]
For some z that may end up being real, imaginary or complex; this is how you get the original ('particle in a box') solution in the first place.
Okay I think I see that. But how do we determine if the wavefunction will be sinusoidal or exponential?
Recall the finite square well problem. What is the condition to get exponential behavior of the wavefunction outside the well?
Oh I see. So if the particle is bound by the potential, we know V > E, so we "guess" the exponential solution. But if the particle is free and E > V, then we guess the sinusoidal solution? Is that the correct interpretation?
Yes, although I wouldn't say it involves "guessing". If you study the form of the Schrödinger equation for the case where Vo > E, then you can see that the solution must be exponential. (But maybe you're using "guessing" more loosely.) Anyway, you're on the right track!
Ah, yes, I'm using "guessing" in the the sense that as I'm learning differential equations, the book tells us to "guess" solutions to the second order differential equations. It's not really guessing, but I've gotten used to the term.
Thanks so much!
  • · Replies 19 ·
  • · Replies 20 ·
