Wave-particle duality at Macro scale?
108 replies · 44K views
I'm guessing English isn't his first language but it reads better in the link of his article he cites:
There are also essential differences, mainly similar to Nelson’s interpretation, motivation is resemblance to quantum mechanics and that instead of standard evolution there is used so called Bernstein process: situation in both past and future (simultaneously) is used to find the current probability density...Abstract ensembles of four-dimensional scenarios also bring natural intuition about Born rule: the squares relating amplitudes and probabilities while focusing on constant-time cut of such ensemble. In given moment, there meets past and future half-paths of abstract scenarios we consider-we will see that the lowest energy eigenvector of Hamiltonian (amplitude) is the probability density on the end of separate one of these past or future ensembles of half paths. Now the probability of being in given point in that moment is probability of reaching it from the past ensemble, multiplied by the same value for the ensemble of future scenarios we consider-is the square of amplitude.
From Maximal Entropy Random Walk to quantum thermodynamics
http://arxiv.org/pdf/1111.2253v3.pdf
I also found this comment by Jarek discussing deBroglie model analogue of the external vibration frequency induced by Couder group interesting:
Much less problematic view was started by de Broglie in his doctoral paper: that with particle’s energy (E = mc2), there should come some internal periodic process (E = ~hω) and so periodically created waves around - adding wave nature to this particle, so that it has simultaneously both of them. Such internal clock is also expected by Dirac equation as Zitterbewegung (trembling motion). Recently it was observed by Gouanere as increased absorption of 81MeV electrons, while this "clock" synchronizes with regular structure of the barrier. Similar interpretation of wave-particle duality (using external clock instead), was recently used by group of Couder to simulate quantum phenomena with macroscopic classical objects: droplets on vibrating liquid surface.The fact that they are coupled with waves they create, allowed to observe interference in statistical pattern of double slit experiment, analogue of tunneling: that behavior depends in complicated way on the history stored in the field and finally quantization of orbits- that to find a resonance with the field, while making an orbit, the clock needs to make an integer number of periods.
bohm2 said:
A very interesting lecture presentation (~ 83 minutes) from Perimeter by Yves Couder:
A Macroscopic-scale Wave-particle Duality : the Role of a Wave Mediated Path Memory
http://pirsa.org/displayFlash.php?id=11100119
I re-viewed the link.
From 70.10
...Couder is talking about deBroglie’s idea of two waves in quantum mechanics : A standing wave surrounding the particle, and a wave representing probabilities, namely the Schrödinger wave. Couder then compares this idea to the experiments with walkers passing through a slit the size of the wavelength of the standing wave generated by the droplet:
“So in fact if you reconsider our experiment: In a way it suggests a sort of implementation of de Brogle’s idea. Because if you look at one trajectory of our wave/particle association, when you look at the passage of.. at this thing passing through the slit. You have a real particle associated with a standing wave that moves through the slit and doesn’t look at all like it is a plane wave.
But if you look at the statistics, then you will see, that the statistics look, as if you had had a plane wave crossing the slit, so in a way (...) this would be the schrödinger wave.”
So I think I can answer my “similar...except”-question: The distribution of the directions of the droplets in Couder’s experiment with walkers going through slits is similar to the Schrödinger equation in the way that it is simply a probability distribution (due to the wavefronts merging after the slit after the droplet has achieved a random direction during the passing of the slit)- reflecting what Bohr convinced Schrödinger about during his famous visit in Copenhagen.
So IF Couder’s group’s experiments are valid analogies to what goes on at the quantum scale, the experiments not only support de Broglie’s ideas of two types of waves (real standing waves AND a probability-wave) at play in quantum mechanics, but also justify the Copenhagen people’s idea of a genuine randomness at play after a measurement, as well as give enormous credit to Einstein’s view that if it is part of this world it’s got to behave classically + it contradicts Bohm’s idea of the Schrödinger wave being physical?
Henrik
I have trouble reconciling these differences. On the one hand, I assumed that the PBR no-go theorem (with some assumptions) requires that the Schrödinger wave be ontic. Furthermore, statistical trajectories conforming to the Bohmian trajectories have been observed experimentally. With respect to the trajectories of single particles in Couder's experiments versus Bohmian, note that the Bohmian trajectories obey the "no crossing rule" which are consistent with experiments unlike Couder's. As Couder writes:
Another difference is that the Bohmian trajectories do not cross the symmetry axis of the system. Those passing on the left (right) of the slits are always deviated to the left (right). This can be seen as a characteristic difference between the Bohmian trajectory that concerns a probability density and the individual trajectory of a single particle.
Grossing et al. have modeled a Couder-type system that does actually respect the "no crossing" rule:
To account for this context, we introduce a "path excitation field", which derives from the thermodynamics of the zero-point vacuum and which represents all possible paths a "particle" can take via thermal path fluctuations. The intensity distribution on a screen behind a double slit is calculated, as well as the corresponding trajectories and the probability density current. The trajectories are shown to obey a "no crossing" rule with respect to the central line, i.e., between the two slits and orthogonal to their connecting line. This agrees with the Bohmian interpretation, but appears here without the necessity of invoking the quantum potential.
They go on to argue for an advantage of their model over Bohmian:
To fully appreciate this surprising characteristic, we remind the reader of the severe criticism of Bohmian trajectories as put forward by Scully and others.The critics claimed that Bohmian trajectories would have to be described as "surreal" ones because of their apparent violation of momentum conservation. In fact, due to the "no crossing" rule for Bohmian trajectories in Young's double slit experiment, for example, the particles coming from, say, the right slit (and expected at the left part of the screen if momentum conservation should hold on the corresponding macro-level) actually arrive at the right part of the screen (and vice versa for the other slit). In Bohmian theory, this "no crossing" rule is due to the action of the non-classical quantum potential, such that, once the existence of a quantum potential is accepted, no contradiction arises and the trajectories may be considered "real" instead of "surreal". Here we can note that in our sub-quantum approach an explanation of the "no crossing" rule is even more straightforward and actually a consequence of a detailed microscopic momentum conservation. As can be seen in Fig. 1, the (Bohmian) trajectories are repelled from the central symmetry line. However, in our case this is only implicitly due to a "quantum potential", but actually due to the identification of the latter with a kinetic (rather than a potential) energy: As has already been stressed in [15], it is the "heat of the compressed vacuum" that accumulates along said symmetry line (i.e., as reservoir of "outward" oriented kinetic energy) and therefore repels the trajectories. Fig. 1 is in full concordance with the Bohmian interpretation (see, for example, [24] for comparison). However, as mentioned, in our case also a "micro-causal" explanation is provided, which brings the whole process into perfect agreement with momentum conservation on a more "microscopic" level.
An explanation of interference effects in the double slit experiment: Classical trajectories plus ballistic diffusion caused by zero-point fluctuations
http://arxiv.org/pdf/1106.5994v3.pdf
A more philosophical paper and slides by Grossing discussing these ideas can be found here:
The Quantum as an Emergent System
http://www.nonlinearstudies.at/files/ggEmerQuM.pdf
http://iopscience.iop.org/1742-6596/361/1/012008/pdf/1742-6596_361_1_012008.pdf
From the Gerhard Grossing et al. paper in the previous link above the authors mentioned a fortcoming paper to explain entanglement/wholeness/non-locality using analogies/insights from the Couder classical "walking" bouncer experiments:
We shall show in a forthcoming paper how this feature of "wholeness" implies the existence of nonlocal correlations. Due to the nonlocal nature of the involved diffusion wave fields, and based on our proposed model, it should be possible to prove a corresponding identity with entangled states in quantum mechanics.
This paper was just posted today:
This, at least, is what we want to propose here, i.e., that there are further insights to be gained from the experiments of Couder's group, which could analogously be transferred into the modeling of quantum behavior. Concretely, we do believe that also an understanding of nonlocality and entanglement can profitt from the study of said experiments. In fact, one indispensable prerequisite for these experiments to work, one basic commonality of all of them, is that the bath is vibrating itself...
A Classical Framework for Nonlocality and Entanglement
http://lanl.arxiv.org/pdf/1210.4406.pdf
There are some new results from the walking droplets that demonstrate how wave-like statistics arise from an underlying pilot-wave dynamics through deterministic chaos.
What do you think?
What do you think?
The video is summarizing most of the stuff linked above. But what is the microscopic equivalent to the vibrating bath seen in droplet experiments? I've come across papers suggesting some form of "intrinsic periodicity" as per de Brogle's idea suggesting that inside the particle there was a periodic process that was equivalent to a clock. Donatello Dolce has published a few papers on this topic, but I haven't seen it much discussed elsewhere:
We interpret the relativistic quantum behavior of elementary particles in terms of elementary cycles. This represents a generalization of the de Broglie hypothesis of intrinsically “periodic phenomenon”, also known as “de Broglie internal clock”. Similarly to a “particle in a box” or to a “vibrating string”, the constraint of intrinsic periodicity represents a semi-classical quantization condition, with remarkable formal correspondence to ordinary relativistic quantum mechanics. In this formalism the retarded local variations of four-momentum characterizing relativistic interactions can be equivalently expressed in terms of retarded local modulations of de Broglie space-time periodicity, revealing a geometrodynamical nature of gauge interaction.
On the intrinsically cyclic nature of space-time in elementary particles
http://arxiv.org/pdf/1206.1140.pdf
This is another paper by the Gerhard Grossing et al. group that uses some of the insights gained from the bouncing/walking droplets in the experiments of Couder's group to model certain QM phenomena:
In a new approach to explain double-slit interference "from the single particle perspective" via "systemic nonlocality", we answer the question of how a particle going through one slit can "know" about the state of the other slit. We show that this comes about by changed constraints on assumed classical sub-quantum currents, which we have recently employed to derive probability distributions and Bohm-type trajectories in standard double-slit interference on the basis of a modern, 21st century classical physics. Despite claims in the literature that this scenario is to be described by a dynamical nonlocality that could best be understood in the framework of the Heisenberg picture, we show that an explanation can be cast within the framework of the intuitively appealing Schrodinger picture as well. We refer neither to potentials nor to a "quantum force" or some other dynamics, but show that a "systemic nonlocality" may be obtained as a phenomenon that emerges from an assumed sub-quantum kinematics, which is manipulated only by changing its constraints as determined by the changes of the apparatus. Consequences are discussed with respect to the prohibition of superluminal signaling by standard relativity theory...
As we employ no "quantum force", therefore, we consider "systemic nonlocality" as a phenomenon that emerges from a sub-quantum kinematics, which is manipulated only by changing its constraints as determined by the changes of the apparatus. In fact, with our approach we have in a series of papers obtained essential elements of quantum theory. They derive from the assumption that a particle of energy E = ħω is actually an oscillator of angular frequency ω phase-locked with the zero-point oscillations of the surrounding environment, the latter of which containing both regular and fluctuating components and being constrained by the boundary conditions of the experimental setup via the buildup and maintenance of standing waves. The particle in this approach is an off-equilibrium steady-state maintained by the throughput of zero-point energy from its vacuum surroundings. This is in close analogy to the bouncing/walking droplets in the experiments of Couder's group, which in many respects can serve as a classical prototype guiding our intuition.
"Systemic Nonlocality" from Changing Constraints on Sub-Quantum Kinematics
http://lanl.arxiv.org/pdf/1303.2867.pdf
Some 2013 papers that add to this interesting work in this subject:
We demonstrate that a coherent wavelike statistical behavior emerges from the complex underlying dynamics and that the probability distribution is prescribed by the Faraday wave mode of the corral. The statistical behavior of the walking droplets is demonstrated to be analogous to that of electrons in quantum corrals.
Wavelike statistics from pilot-wave dynamics in a circular corral
http://math.mit.edu/~bush/wordpress/wp-content/uploads/2013/07/Harris-Corrals-2013.pdf
Interaction of walking drops and the surface waves reflected from the boundaries or from other drops leads to a variety of interesting phenomena reminiscent of quantum mechanics (Bush 2010). Examples include tunnelling across a subsurface barrier (Eddi et al. 2009b), single-particle diffraction in both single- and double-slit geometries (Couder & Fort 2006), quantized orbits analogous to Landau levels in quantum mechanics (Fort et al. 2010) and orbital level splitting (Eddi et al. 2012). Harris et al. (2013) considered a drop walking in confined geometries, and demonstrated that the resulting probability distribution function is simply related to the most unstable Faraday wave mode of the cavity. Rationalizing these remarkable macroscopic quantum-like phenomena provided the motivation for this study.
Droplets bouncing on a vibrating bath
http://math.mit.edu/~bush/wordpress/wp-content/uploads/2013/07/MB1-2013.pdf
Our results form the basis of the first rational hydrodynamic pilot-wave theory.
Droplets walking on a vibrating bath: Towards a hydrodynamic pilot-wave theory
http://math.mit.edu/~bush/wordpress/wp-content/uploads/2013/07/MB2-2013.pdf
Finally, we have highlighted a mixed state, in which the walking drop shifts between two distinct modes, a state that may serve as an analog of a superposed state in quantum mechanics.
Exotic states of bouncing and walking droplets
http://windw.dk/2013Bouncing.pdf
Another paper on the droplets' quantum like behavour. I'm am not able to judge the paper professionally as I'm not a physicist, but it seems to me it's claiming that the behavour of the droplets are not only quantum like but equivalent to quantum mechanics when the differences of the systems are taken into consideration and if experiments reveal certain diffraction patterns. But I'm certainly not sure I'm right about that assumption?
Droplets moving on a fluid surface: interference pattern from two slits
http://arxiv.org/pdf/1307.6920v1.pdf
..Also the paper mentions that droplets and ANTIdroplets can form from waves meeting each other. Something which seems to take place in experiments with oil as well as water. I'd never heard about that.
So my brain had an idea while reading the latter part of this thread... (And forgive me if this has already been discussed/addressed via reference here.) Could there be interesting things to do with this setup (the walker-table) by augmenting the (classical) 'quantum simulations' with_actual_quantum components/extensions/etc.? Unfortunately I don't have any suggestions off the top of my head but it seems there might be interesting qutantum-classical hybrid interactions/experimental scenarios to be explored? ..Are there constraints working against such endeavors due to the 'table-walker' setup?
Also as a quick more general aside: It's obvious that the 'walker' experiments that are the subject of this thread produce a quite amazing variety of quantum-like effects, especially upon first blush for someone not ever having been exposed to such an experimental setup before, or ever even considered the_possibility_ of such a thing! Acknowledging that--I'm wondering if someone can tell me what 'quantumy' effects it CAN'T reproduce?? ..Also (last q): Are there any lorentz-invariance-related issues hanging around in all this?
Thanks again to those taking time to aggregate sources and reference materials and compose or participate in threads such as this one.(!)
As acknowledged by the some of these authors themselves in this slide presentation, those experiments are still far from QM for the following reasons:
- Macroscopic scale : no relation with Planck constant.
- The system is two-dimensional.
- The system is dissipative and sustained by external forcing.
- This forcing imposes a fixed frequency: the “energy” is fixed
- The waves live on a material medium: there is an “ether
A macroscopic-scale wave-particle duality
http://www.physics.utoronto.ca/~colloq/Talk2011_Couder/Couder.pdf
Another interesting paper recently published by the Grossing group on their model and Born's rule, they also touch on your latter point regarding lorentz-invariance-related issues, etc. :
It has been shown in a series of papers that phenomena of standard quantum mechanics like Gaussian dispersion of wave packets, superposition, double slit interference, Planck's energy relation, or the Schrodinger equation can be assessed as the emergent property of an underlying sub-structure of the vacuum combined with diff usion processes reflecting also the stochastic parts of the zero-point field, i.e. the zero point fluctuations. Thus we obtain the quantum mechanical results as an averaged behavior of sub-quantum processes. The inclusion of relativistic physics has not been considered yet, but should be possible in principle.
Born's Rule as Signature of a Super-Classical Current Algebra
http://arxiv.org/pdf/1308.5924.pdf
“All our experiences tell us we shouldn't have two dramatically different conceptions of reality — there must be one huge overarching theory,” says Abhay Ashtekar, a physicist at Pennsylvania State University in University Park.
Yes, it seems that unification has been the norm in the sciences but I think that one must also recognize that this is still at most a hope that might not be realized, either because nature really is not unified/monistic, or because human cognitive capacities are not capable of discovering that unity. Either alternative is a possibility, I think.
dont despair, is the zeigeist of this epoch.
are you agnostic ?.
audioloop said:
.dont despair, is the zeigeist of this epoch..
There is hope I think. It is not quantum mechanics. But something which is not purely a wave goes through two holes at one time in a classical system. That takes some of the mystery out of quantum mechanics for me. QM might not be unexplainable after all.
And to me it is exiting to follow the attempts to see how far this droplett-analogy to QM can be stretched. How much of the weirdness from QM it might show parallels to in this limited 2-dimensional system. Entanglement of course is the big one.
- Henrik
- Henrik
there are similar results from epistemic models.
But it seems to me, that given some arguably reasonable assumptions, ψ-epistemic models can be ruled out as per PBR theorem? So, if one accepts realism, we are stuck with trying to conceptualize entanglement/non-locality in ontic terms which leads to difficulties as noted by van Fraassen:
To speak of instantaneous travel from X to Y is a mixed or incoherent metaphor, for the entity in question is implied to be simultaneously at X and at Y – in which case there is no need for travel, for it is at its destination already...one should say instead that the entity has two (or more) coexisting parts, that it is spatially extended.
The reality of relations: the case from quantum physics
http://philsci-archive.pitt.edu/9959/1/Relations290813.pdf
It is interesting that quite a few authors are suggesting that our familiar space-time is something that might 'emerge' from some more fundamental stuff that is non-spatio-temporal. On the other hand, if one accepts some form of ontic dualism as some Bohmians (e.g. Bohm, Valentini) do, other problems arise:
However, one can with good reason object that simply adding a quantum force when passing from classical to quantum mechanics is an ad hoc move: that force cannot be traced back to properties of the particles, as the gravitational force can be traced back to mass and the electromagnetic force to charge. Moreover, that force cannot be treated in terms of a field defined on physical space, for it does not permit to assign values to points of space-time. If the wave-function, which is supposed to stand for the quantum force on this view, represents a field, it can only be a field on configuration space, that is, the very high dimensional mathematical space each point of which corresponds to a possible configuration of the particles in physical space. However, it is entirely mysterious how a field on configuration space could influence the motion of particles in physical space.
audioloop said:
there are similar results from epistemic models..
Yes. I should have been more precise: QM might not be unexplainable in classical terms after all. Lots of explanations already.
audioloop said:
are you agnostic ?
No, I just think that like all other organisms we have cognitive limitations. There might be stuff we may never be able to fully understand/conceptualize.
imo pbr is not definitive and there are epistemic-ontic models unlike epistemic-epistemic models and ontic models..
Indeed the Couder's experiments are amazing - giving a hope to get below the QM.
I've participated in "Emergent Quantum Mechanics" conference in Vienna two years ago - he gave the opening talk and most of speakers expressed excitation about these experiments. If someone is interested, there is second edition (free admission) in a few weeks and Coder will be there: http://srv14116.omansrv14.omanbros.com/
If we agree that this is the proper view on wave-corpuscle duality, so the next step should be finding a concrete constructions for the real particles: with some localized properties (like charge), conjugated with delocalized wave around, for example caused by an internal periodic dynamics (de Broglie's clock/zitterbewegung).
Localized constructs of the field are generally called soltions, to get e.g. charge conservation we can use topological solitons, and they often have some internal periodic dynamics, like so called breathers ...
How do you see consequences of this view on wave-corpuscle duality?
There are available 3 new papers about these classical objects with wave-particle duality:
One is, like seen in this video, about that their trajectories average to kind of quantum orbitals: http://math.mit.edu/~bush/wordpress/wp-content/uploads/2013/07/Harris-Corrals-2013.pdf
and there are two general papers about their behavior: http://math.mit.edu/~bush/wordpress/wp-content/uploads/2013/07/MB1-2013.pdf , http://windw.dk/2013Bouncing.pdf
If someone is interested in taking this view on wave-corpuscle duality into real particles, there are a few issues:
- the most important should be finding concrete models for particles in this picture: see them as some localized constructs of the field (so called solitons), conjugated with waves they create due to some their internal periodic process (like breathers: http://en.wikipedia.org/wiki/Breather ) - discussion: https://www.physicsforums.com/showthread.php?t=710042
- like in the first paper above, long time thermodynamical behavior of such localized objects should agree with quantum predictions, like leading to the quantum ground state probability distribution. Standard random walks usually disagree with that, but it turns out that if we choose it right (accordingly to the maximal uncertainty principle), there is no longer disagreement of such approaches based on Maximal Entropy Random Walk - discussion: https://www.physicsforums.com/showthread.php?t=710790
- another issue is understanding approximately classical short time behavior of e.g. such electrons - we know that Bohr model does not give a good agreement with quantum predictions. But it neglects that electrons have strong magnetic dipole moment - are tiny magnets. Adding these corrections: classical spin-orbit interaction, we get free-fall atomic model with better agreement - discussion: https://www.physicsforums.com/showthread.php?t=710464
What other issues about seeing particles in this view on wave-corpuscle duality should we have in mind?
bohm2 said:
This is a real cool video show this quantum-like macroscopic behaviour through the double-slit
Yves Couder . Explains Wave/Particle Duality via Silicon Droplets [Through the Wormhole]
https://www.youtube.com/watch?v=W9yWv5dqSKk
Nice video,
I couldn't help but notice that the droplet's waves propagate ahead of it which doesn't seem to be the case at the quantum level.
Mectaresch, see also this video:
Why you think that waves (of quantum phase) does not propagate ahead of particle in QM?
In stationary Schrödinger solution phase changes periodically: exp(-iEt) ... in de Broglie's interpretation particle has some internal periodic motion - is a tiny oscillator, creating waves of quantum phase around - "piloting" the corpuscle (amplitude) e.g. while interference.
You just make Madelung transformation: take psi=R exp(iS) and write Schroedinger equations for this action (S) and density rho=R^2. For density you get standard continuity equation, while for S you get Hamilton-Jacobi equation - exactly like for classical mechanics, but modified by h^2 correction because of interaction with these "pilot" waves of quantum phase: http://en.wikipedia.org/wiki/De_Broglie–Bohm_theory#Derivations
bohm2 said:
Another paper on this topic that came out:
Wave-particle duality in classical mechanics
http://lanl.arxiv.org/pdf/1201.4509.pdf
bohm2: Does the "lack of information about all degrees of freedom of a soft body" explain away the Uncertainty Principle as well?
I'm not sure about the details of Davydov's model (in the link) but these models can derive Heisenberg's uncertainty relations. See "Derivation of the Heisenberg Uncertainty relations" in this paper by Grossling:
Sub-Quantum Thermodynamics as a Basis of Emergent Quantum Mechanics
http://www.mdpi.com/1099-4300/12/9/1975
I thought this work on supercorrelations and Bell's theorem is interesting since it seems to be compatible with some of Couder's and Grossing's models:
In systems described by Ising-like Hamiltonians, such as spin-lattices, the Bell Inequality can be strongly violated. Surprisingly, these systems are both local and non-superdeterministic. They are local, because 1) they include only local, near-neighbor interaction, 2) they satisfy, accordingly, the Clauser-Horne factorability condition, and 3) they can violate the Bell Inequality also in dynamic Bell experiments. Starting from this result we construct an elementary hidden-variable model, based on a generalized Ising Hamiltonian, describing the interaction of the Bell-particles with a stochastic ‘background’ medium. We suggest that such a model is a simple version of a variety of recently developed ‘sub-quantum’ theories, by authors as Nelson, Adler, De la Pena, Cetto, Groessing, Khrennikov, all based on a background field. We investigate how the model might be turned into a realistic theory. Finally, it appears that background-based models can be tested and discriminated from quantum mechanics by a straightforward extension of existing experiments.
Can ‘sub-quantum’ theories based on a background field escape Bell’s no-go theorem ?
http://www.perimeterinstitute.ca/videos/can-sub-quantum-theories-based-background-field-escape-bell-s-no-go-theorem (recent video from Perimeter Institute)
Ref. [34] mentions, as one of its sources of inspiration, recent and spectacular experiments by Couder et al. [36], in which quantum behavior (e.g. double slit interference) is reproduced by macroscopic particles, namely oil droplets. The latter are excited by an external field (the vibration of an oil bed) imparting Brownian motion to the droplets. There seems to be a common denominator in these theories [33-35] and experiments [36], a kind of ‘contextuality’, namely the fact that the precise shape of the (zero-point) field (λ for us) depends on the ‘context’, i.e. the boundary conditions of the whole experimental set-up including the parameters of all, even remote, detectors.
Bell's Theorem: Two Neglected Solutions
http://arxiv.org/ftp/arxiv/papers/1203/1203.6587.pdf
Violation of the Bell-Inequality in Supercorrelated Systems
http://arxiv.org/vc/arxiv/papers/1211/1211.1411v1.pdf
This might be a dumb question but does anybody know what happens to the interference pattern in these quantum-like macroscopic experiments if they place a detector (or some disturbance) behind the slits? Is there any effect on the interference pattern analogous to QM?
This is another piece just written today on the Couder experiments arguing that those experiments are still far away from QM, particularly due to the non-locality/entanglement issue of QM:
One area where the walkers' analogy with quantum mechanics fails, however, is entanglement – the weirdest quantum phenomenon of all that describes how the physical state of two particles can be intricately linked no matter how far apart in the universe they are.
For this to happen, a wave must occupy a very high number of dimensions so particles can affect one another over large distances, faster than the speed of light. However, in a walker system the waves will always occupy just two dimensions, given by the length and width of the oil tank.
"If one thinks of [entanglement] as central to quantum theory, it cannot possibly be reproduced in the [walker] system," Tim Maudlin of New York University told Physics World.
Can an oil bath solve the mysteries of the quantum world?
http://phys.org/news/2013-11-oil-mysteries-quantum-world.html
Having said that, it has been shown by Allahverdyan, Khrennikov and Nieuwenhuizen, that entanglement can be realized in a classical way for a system consisting of two Brownian particles.
We have uncovered the phenomenon of brownian entanglement: a correlation effect between the coordinates and the coarse-grained velocities of two classical brownian particles, which resembles the quantum entanglement. In contrast to the latter, which is presently given a fundamental status, the brownian entanglement —as the very subject of statistical physics— arises out of coarse-graining (incomplete description) reasons. In that respect it is similar to other basic relations of the statistical physics, such as the second law . In the present situation the coarse-graining comes due to the time-scale separation: the evolution of the momenta of the brownian particles is very fast and cannot be resolved on the time-scales available to the experiment.
Brownian Entanglement
http://arxiv.org/pdf/quant-ph/0412132v1.pdf
