Waveguide Question: TE & TM Waves Explained
  • Context: Undergrad
  • Thread starter Thread starter pierce15
    Waveguide
The discussion revolves around the characteristics of transverse electric (TE) and transverse magnetic (TM) waves in waveguides, as well as the behavior of laser beams in relation to waveguides. Participants explore the nature of wave propagation in waveguides and the implications of incident monochromatic plane waves.
  • Some participants express confusion about the distinction between TE and TM waves in waveguides, particularly regarding their relationship to incident plane waves.
  • One participant explains that waveguides do not support transverse electromagnetic (TEM) waves, and that TE waves have electric fields perpendicular to the direction of propagation while TM waves have magnetic fields perpendicular to it.
  • It is proposed that incident waves will generally excite multiple TE and TM modes, and that the sum of these modes can match the characteristics of the incident plane wave.
  • Another participant raises a question about characterizing laser light as a superposition of plane waves and whether it can pass through a waveguide without exciting TE or TM modes.
  • Responses indicate that Fourier analysis may be applicable to these systems and that the waveguide may have minimal effects on laser beams under certain conditions.
  • Discussion includes the idea that laser output can be described in terms of cavity modes, with most output being a single transverse mode, but higher-order modes are also possible.
Participants generally agree on the definitions of TE and TM waves and their behavior in waveguides, but there is uncertainty regarding the effects of laser beams on waveguides and whether they excite TE or TM modes. The discussion remains unresolved on the specifics of these interactions.
Limitations include the potential complexity of calculating wave interactions in waveguides and the dependence on specific beam shapes and waveguide dimensions. The discussion does not resolve the extent of the waveguide's effect on laser beams.
pierce15
I am a little confused about the difference between TE and TM waves in a waveguide. Let's say a monochromatic plane wave is incident on a wave guide. Then will this result in both TE and TM waves such that the sum of the guided waves at the entrance of the waveguide agrees with the plane wave?
Science news on Phys.org
This issue is that a waveguide does not support transverse electromagnetic (TEM) waves, where both E and B are perpendicular to the direction of propagation. So the waves that propagate must have a component of the electromagnetic field parallel to the direction of propagation. Waves for which the electric field is perpendicular to the direction of propagation are called transverse electric (TE); these waves have a component of the magnetic field along the direction of propagation. Likewise waves for which the magnetic field is perpendicular to the propagation direction are TM, and these waves have a component of E along the propagation direction. But it is also possible for a wave in a waveguide to have components of both E and B along the propagation direction, for example:
Yep. In general it will excite many TE and TM modes. The wave will have E and B in all directions, including along the direction of propagation.
EDIT: note that in general there will be a wave reflected from the waveguide as well, which complicates things a little. But conceptually you have the right idea. Actually performing these kinds of calculations can be fairly messy and not so insightful, in my experience (from many years ago...).
jason
Thanks, that helps.
An unrelated question, but one that started when I was thinking about this: is it possible to characterize the light coming out of a laser beam as a superposition of plane waves (i.e. Fourier transform of some function)? Or to handle it in some other way while still thinking about E and B?
My intuition is that if you shine a laser into a hollow cavity it seems like it would pass right through without exciting any TE or TM modes, if the width of the laser beam is less than the waveguide radius (assuming circular cylinder).
Yes, Fourier analysis can be useful for these types of systems.
Reagarding the laser beam, for all practical purposes the waveguide has essentially no effect. If you have ever looked through a metal pipe you know that optical frequencies have no trouble propagating. If you want the exact answer, then the waveguide will have a small effect - the extent of which depends on the details of the beam shape ans the size of the waveguide. I suspect it will be unmeasurable in many cases, though.
pierce15 said:
Thanks, that helps.
Within a resonant cavity, the EM field consists of stable modes: both longitudinal and transverse. The laser output consists of coupling the internal modes to the outside via a partially reflecting mirror. The usual way to describe the emitted field is to decompose the emitted beam in terms of the cavity modes- most laser output is a single transverse mode (e.g. a Gaussian beam), but higher-order modes (Laguerre-Gaussian or Hermite-Gaussian, depending on the cavity cross-section) are possible as well. Other, more complicated cavities (unstable resonators, for example) have different eigenmodes.
https://courses.engr.illinois.edu/ece455/Files/Galvinlectures/02_CavityModes.pdf
One helpful fact is that the Fourier transform of a Gaussian function is another Gaussian- making it trivial to perform some basic optical analysis.
Thanks to both of you.
18K
