Ways on how visualize the deflected shape of a simple structure?
  • Thread starter Thread starter driedupfish
    Shape Structure
Visualizing the deflected shape of a simple structure can be effectively achieved using shear and moment diagrams. Understanding these diagrams involves solving differential equations and integrating to find deflections, especially under distributed loads. It's essential to first determine reaction forces from point loads using static equilibrium methods. While the explanation can be complex, resources like Wikipedia provide a structured approach to learning the procedure. Mastering this technique will enable accurate visualization of beam deflections along its axis.
driedupfish
Hi guys, what are some ways to visualize the deflected shape of a simple structure?
I know that there is no slope or deflection at fix ends. No deflection at supports (roller, fix ends, etc).
Also, I am not really sure what a kink is.
Thanks
Hey driedupfish,
This is my first post, but this is a question that I feel like I can answer, even if not in the most detailed way...
I was going to write out an example and walk you through it and its theory, but then I realized how long it would be, and if you're like me, you'd get halfway through it and just stop reading. Besides, I doubt I'm really the best at explaining it. Instead, I'll give you the short answer. The way I learned was to use shear and moment diagrams. I can't give you a good overview of how to do it in a forum, really. It took about a week of lectures before I understood it.
Finding deflections of point loaded members is fairly straight forward, but distributed loads can get kinda hairy at times, especially if you don't use superposition. The solution of these diagrams requires solving some simple differential equations with initial conditions, but all you really have to do is integrate.
If you can do statics, find the reaction forces caused by the point load (using summation of moments or forces in x-axis or y-axis).
I was going to go into more detail here, but I'm beginning to see how it would really become unclear in text. I'd suggest you look into Shear and Moment diagrams.
Take if from Wikipedia: http://en.wikipedia.org/wiki/Shear_and_moment_diagram"
I'd skip down to the "Procedure" section.
Once you can apply it to your own scenario reliably, you just have to integrate the Moment Diagram and you'll have the Deflection Diagram which will tell you how much the beam has deflected at any given point along the axis.
Not really the best answer to your question, admittedly. But hopefully this will get you pointed in the right direction.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
  • · Replies 16 ·
