What is the weight of air in a 30 gallon tank at 100 PSI?
  • Context: High School
  • Thread starter Thread starter shawn b
    Air Psi Weight
The discussion revolves around calculating the weight of air in a 30-gallon tank pressurized to 100 PSI. Participants explore the implications of air density and the ideal gas law in this context.
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant mentions the density of air at sea level pressure (14.7 psi) as 0.075 lb/ft³ and provides a conversion factor of 7.46 gallons per cubic foot.
  • Another participant references the ideal gas law as relevant to the discussion.
  • A later reply humorously suggests that the weight of the air could be simply "2 pounds."
Participants present varying approaches and calculations, but there is no consensus on the exact weight of the air in the tank or a definitive method for calculating it.
Participants have not fully explored the implications of pressure changes on air density, and assumptions regarding temperature and humidity are not addressed.
Individuals interested in physics, engineering, or practical applications of gas laws may find this discussion relevant.
shawn b
Some friends and I were moving a 30 gallon air compressor and after we moved it decided it would have been better to let the air out first. I would like to know how much more the tank weighs with it full of air at 100 PSI. Is there a simple formula to use to make this calculation?
Thanks so much for your help.
Shawn Boyers
Well, the density of air at sea level pressure (14.7 psi) is .075 lb/ft^3 and there are 7.46 gal/ cu ft...
Ideal gas law...
2 pounds :smile:
