Weight of landing from jumping
  • Thread starter Thread starter andrewz182
    Weight
A 160 lb person jumping from a height of 2 feet can exert a force greater than their body weight upon landing, potentially exceeding 400 lbs on a scale. The calculation of this force involves the principles of physics, specifically Newton's second law, where force equals mass times acceleration. The instantaneous force measured by a scale at the moment of impact will be influenced by factors such as deceleration and the compression of the scale. The debate centers around understanding how these variables affect the force exerted upon landing.
  • Understanding of Newton's second law of motion
  • Basic knowledge of force, mass, and acceleration
  • Familiarity with concepts of momentum and deceleration
  • Awareness of factors affecting force measurement, such as air resistance
  • Research the physics of jumping and landing dynamics
  • Learn about force measurement techniques and equipment
  • Explore the effects of deceleration on impact force calculations
  • Investigate the role of air resistance in jumping scenarios
Physics students, sports scientists, fitness trainers, and anyone interested in biomechanics and the physics of jumping and landing.
andrewz182
if i were a 160 lb person who could jump a height of 2 feet, what would be my "weight/force/momentum" or whatever measurement used that will result in a calculation of pounds in the end.
this is in no way me asking for help with hw, this is over a debate i had with a friend, and neither of us can really figure it out...
would it be (mass x acceleration x time)??
what do you mean by
or "pounds of force"
what do mean by "in the end"? I don't understand what is the debate about either
i mean at the point of impact with the ground.
ok to specify: what weight would a scale read if i were to jump on it from 2 feet?? would it just be calculating momentum??
so I guess you are saying that whether the downward force measured by a scale on the ground would register a bigger reading if you jump onto the scale as oppose to standing still on it? what do you think?
but more specifically, would it be possible for a 160 lb person, who is able to jump 2 feet up in the air, to exert enough force upon a scale to read over 400 lbs?
Force is equal to mass times acceleration. The same velocity can be achieved with a faster acceleration over a shorter period of time. There's no limit to the amount of force involved in a 2 foot landing, other than the maximum deceleration will be limited by how much compression there is at the contact point.
the force you are talking about is probably the instantaneous reading NOT at impact but when your body has just been fully decelerate to velocity zero I think, and before the scale re-adjust and show your "true weight"
mind you there are all those usual stuff like air resistance, or how you may destroy the scale etc...ie. what is the displacement during deceleration (otherwise it is probably not just 2 feet the total distance travelled) or whether deceleration is constant during that time...
44K
  • · Replies 19 ·
  • · Replies 16 ·
