- 448
as usual XXXchris XX you are spot on..it still twists but the independent rear suspension permits the torque to be BETTER transmitted to the pavement. there is still lateral and longintudenal twist going on though not so readily apparent. The independent swing arms " flex" to better accommodate the weight transfer where as the solid differential can not conform to varying weight transfer AS WELL and hence the wheelie and tork twist.
r power - most solid rear differentials have different length axles. the right side being shorter
then the left side. independent diffs have CV joints and same length axles and the diff is mounted at vehicle center line.
