Weyl Spinors Transformation, QFT1, Peskin, Chapter 3
This discussion revolves around the transformation properties of Weyl spinors in the context of quantum field theory, specifically referencing concepts from Peskin's textbook. Participants are exploring the mathematical identities involving Pauli matrices and their implications for the transformation of left-handed and right-handed spinors.
  • Participants are attempting to evaluate transformation equations for Weyl spinors using Pauli matrices. There are discussions about verifying identities involving these matrices, as well as questions regarding the treatment of complex conjugates in transformations.
The discussion is ongoing, with participants providing insights into the mathematical relationships between the Pauli matrices and the transformations of spinors. Some participants are questioning the assumptions behind the transformations and the necessity of considering the entire expression when applying transformations.
There are references to specific equations and identities from the textbook that are central to the discussion, as well as a focus on the implications of the transformation properties of spinors. The complexity of the topic is acknowledged, with participants expressing a desire to understand the underlying principles rather than simply arriving at a solution.
Pouramat
The transformation law for Weyl spinors is as following (3.37); these transformation laws are connected by complex conjugation; using the identity (3.38)
(3.37) and (3.38) peskin
\begin{align}
\psi_L \rightarrow (1-i \vec{\theta} . \frac{{\vec\sigma}}{2} - \vec\beta . \frac{\vec\sigma}{2}) \psi_L \\
\psi_R \rightarrow (1-i \vec{\theta} . \frac{{\vec\sigma}}{2} + \vec\beta . \frac{\vec\sigma}{2}) \psi_R
\end{align}
I really cannot evaluate these from boost and rotation generator which was introduced in (3.26) and (3.27) Peskin.
Although the main porblem is the identity introduced below:
\sigma^2 \vec\sigma^* = -\vec \sigma \sigma^2
My attempt:
\sigma^1 =
\begin{pmatrix}
0 & 1 \\
1 & 0 \\
\end{pmatrix};
\sigma^2 =
\begin{pmatrix}
0 & -i \\
i & 0 \\
\end{pmatrix};
\sigma^3 =
\begin{pmatrix}
1 & 0 \\
0 & 1 \\
\end{pmatrix}
the h.c. of the Pauli Sigma matrices is as following:
(\sigma^1)^* =
\begin{pmatrix}
0 & 1 \\
1 & 0 \\
\end{pmatrix};
(\sigma^2)^* =
\begin{pmatrix}
0 & i \\
-i & 0 \\
\end{pmatrix};
(\sigma^3)^* =
\begin{pmatrix}
1 & 0 \\
0 & 1 \\
\end{pmatrix}
so ##\sigma^2 = diag(1,1)##,right?
I think my problem is that I cannot write the identity in components form.
Of course ##\sigma^3=\mathrm{diag}(1,-1)##. I'd say the most simple way is just to prove the equation by doing the matrix multiplications for the three matrices :-).
Ohhh, Yes, it was a typo :)
the LHS:
\large \begin{pmatrix}
0 & 1 \\
1 & 0 \\
\end{pmatrix}
\begin{pmatrix}
0 & i \\
-i & 0 \\
\end{pmatrix}
\begin{pmatrix}
1 & 0 \\
0 & -1 \\
\end{pmatrix} =
\begin{pmatrix}
1 & 1+i \\
1-i & -1 \\
\end{pmatrix}
which should be equal to RHS:
-\large( \begin{pmatrix}
0 & 1 \\
1 & 0 \\
\end{pmatrix}
\begin{pmatrix}
0 & -i \\
i & 0 \\
\end{pmatrix}
\begin{pmatrix}
1 & 0 \\
0 & -1 \\
\end{pmatrix})
\begin{pmatrix}
-1 & 1+i \\
1-i & 1 \\
\end{pmatrix}
but it is not!
I have no idea what you are doing here. You are supposed to show that (I'll give one example)
$$\sigma^2 \sigma^{1*}=-\sigma^1 \sigma^2.$$
Take the right-hand side and use the anti-commutation relations
$$\{\sigma^j,\sigma^k\}=2 \delta^{jk}$$
to get
$$-\sigma^1 \sigma^2 =+ \sigma^2 \sigma^1.$$
Since ##\sigma^1## is real this hows that
$$-\sigma^1 \sigma^2=\sigma^2 \sigma^{1*}.$$
Now you can prove the other two identities!
to get
thank you @vanhees71. Yes you are right.
dear @vanhees71
And 1 more question, do you have any idea to explicitly show that ##\sigma^2 \psi^*_L## transforms like a right-handed spinor? using the identity.
Take the conjugate complex of the transformation law for ##\psi_L## and multiply with ##\sigma^2##. Then use the (anti-)commutation relation for the complex conjugated Pauli matrices just proven.
I have a question to that. Peskin asks us to show that ##\sigma^2\psi_L## transforms like a right-handed spinor. So why can we just consider the transformation of ##\psi_L## alone to then multiply by ##\sigma^2##, and not the transformation of whatever the object ##\sigma^2\psi_L## is?
Edit: I think that my question is why we don't need to take the ##\sigma^2## in front into account when doing the transformation. After all, ##\sigma^2\psi_L\ne\psi_L##, so it should be taken into account when transforming, right?
You now the transformation representing Lorentz transformations. The infinitesimal version is already sufficient, i.e., the generators for left- and right-handed Weyl spinors. Then it's just Pauli-matrix gymnastics to prove that ##\sigma^2 \psi_L## transforms like ##\psi_R##. Mathematically it's of course not the special pauli matrix ##\sigma^2## which is behind this but the antisymmetric product of two spinors given by ##\epsilon_{ij}## (with ##\epsilon_{12}=-\epsilon_{21}=1##) which is relevant here.
That it's an antisymmetric product instead of a symmetric hints at the fact that one should rather argue with Grassmann-number valued fields for fermions, which is what comes out also using the path-integral formulation.
I’m sorry, but I fail to see how this answers my question. What doesn’t make sense for me is the following:
We are asked to show that the object ##\sigma^2\psi_L^*## (in my previous post I forgot the complex conjugate, sorry) transforms as a right-handed spinor. For me, this means that we need to consider $$\sigma^2\psi_L^*\to(\sigma^2\psi_L^*)’.$$However, you are saying that we should consider $$\psi_L^*\to(\psi_L’)^*,$$to then just multiply by ##\sigma^2##. I can see that this gives the correct result, but I fail to see why we are allowed to do it like this, considering that, in general, these are two different quantities. I hope that this clarifies my confusion.
But then you solved the problem. I don't understand, what's still unclear.
I wouldn't consider it solved, since I don't know why I am allowed to do the transformation like this. The goal for me is to not blindly solve it and move on, but to understand why it works like this. What I want to know is why I can consider the transformation ##\psi_L^*\to(\psi_L')^*##, even though one is asked to consider the transformation ##\sigma^2\psi_L^*\to(\sigma^2\psi_L)'##, since we are asked to show that ##\sigma^2\psi_L^*## transforms as a right-handed spinor. I fail to see what confuses you in my question...
Why? If you know how ##\psi_L## transforms, you can just take the conjugate complex of the equation to know how ##\psi_L^*## transforms. Then you multiply by ##\sigma^2## to find out our ##\sigma_2 \psi_L^*## transforms and compare this with the transformation of ##\psi_R##.
  • · Replies 20 ·
