What actually is threshold frequency?
Threshold frequency refers to the minimum energy required to remove an electron from a solid, which is determined by the work function rather than the ionization energy of individual atoms. In solids, properties differ significantly from isolated atoms due to the formation of energy bands, making atomic-level considerations less relevant for threshold frequency discussions. For example, the first ionization energy of a copper atom is approximately 7.7 eV, while the work function for copper metal is around 4.6 eV, highlighting the distinction between atomic and solid-state properties. The concept of work function applies specifically to solids, and for individual atoms, the threshold frequency relates to the energy needed to ionize an electron from the highest energy level to infinity. Understanding these differences is crucial in solid-state physics.
Clara Chung
For example a metal atom have 3 electrons which occupies 2 energy level. Is the threshold frequency = the energy needed to bring an electron in E2 to E(infinity) / h?
You need to understand one very important concept here. When atoms are together to form a solid, many of the individual properties of isolated atoms are no longer relevant. A solid has many properties that an individual atom does not have. This includes the formation of "energy bands" in solids, whereas in atoms, you have discrete energy levels.
So your question here doesn't make any sense because you are asking a question about a "metal", which is a solid, based on the valence shell of an individual atom. While this may be relevant when one probes deeper energy state of the metal, it is no longer relevant when you talk about "threshold" frequency or energy to cause the first ionization.
For example, the first ionization energy of Cu atom is ~7.7 eV. Yet, for Cu metal, the work function, and thus, the threshold energy for photoemission, is ~4.6 eV. These two numbers are different!
More is Different! Solid state physics is not simply "a lot of atomic physics".
Zz.
Likes Biker and Clara Chung
Zz.
Thanks for telling me that an atom from a metal has different properties from a metal.
So work function is a term for a solid only?
If I consider an atom only, is "threshold frequency * h" or "energy to cause the first ionization "= The energy needed to raise an electron from the highest energy level to infinity?
thanks a lot
Thread 'Colors in a plasma globe'
I have a common plasma globe with blue streamers and orange pads at both ends. The orange light is emitted by neon and the blue light is presumably emitted by argon and xenon. Why are the streamers blue while the pads at both ends are orange? A plasma globe's electric field is strong near the central electrode, decreasing with distance, so I would not expect the orange color at both ends.
  • · Replies 35 ·
