What Are Rosen Coordinates in Gravitational Wave Analysis?
  • Thread starter Thread starter CoordinatesPLZ
    Coordinates
CoordinatesPLZ
I see a number of gravitational wave analytic solutions with the metric given in terms of Rosen coordinates. I have no idea what these coordinates are. How do I perform a coordinate transformation from Rosen coordinates to traditional (t,x,y,z) Euclidean\Cartesian coordinates? Also, is there a difference between Rosen coordinates and Eisenstein-Rosen coordinates?
Thanks
CoordinatesPLZ
A coordinate system for the description of gravitational plane waves:
ds2 = 2 du dv + gij(u) dyi dyj.
As opposed to Brinkmann coordinates for the same wave:
ds2 = H(u) du2 + 2 du dv + dx2 + dy2.
Here's a reference
that discusses both, and how to convert one to the other.
That doesn't directly answer my question. Also, I am not familiar with Brinkmann coordinates. If we suppose the line element in Rosen coordinates in flat space-time is:
ds2=2 du dv+dy12+dy22
Then we can deduce the possible coordinate mapping to Cartesian coordinates of
t = (u-v)/√2
x = y1
y = y2
z = (u+v)/√2,
Assuming a <-1,1,1,1> metric signature
Is this the correct mapping from Rosen coordinates to Cartesian coordinates?
Sorry. What IS your question? You say you want to know what Rosen coordinates "are", but that question has no answer. Coordinates in a curved spacetime do not always have a simple interpretation.
If you're interested in gravitational waves, you should learn about Brinkmann coordinates. Rosen coordinates have several drawbacks. One: they are not unique. Two: they can develop coordinate singularities (caustics). That's why they are not generally used.
That's one possibility. Here's another instance of a plane wave in Rosen coordinates that is also flat:
ds2 = 2 du dv + u2(dy12 + dy22)
t = (u-v)/√2
x = y1
y = y2
z = (u+v)/√2,
In a flat spacetime, (u, v, y1, y2) are called light-cone coordinates, and (t, x, y, z) are called Minkowski coordinates. The terms Euclidean and Cartesian do not apply!
My problem is I have a formula for the metric tensor in Rosen coordinates and I would like the metric tensor in Minkowski spacetime. To go from one to the other I need the coordinate mapping, thus, how do I transform the coordinates from Rosen coordinates to Minkowski Coordinates?
Can't be done. A gravitational wave is a curved spacetime, and Minkowski coordinates exist only in flat space. You can't turn a curved spacetime into a flat spacetime just by changing the coordinates. A gravitational wave is not just Minkowski space written in some weird set of coordinates.
You can certainly do the z = (u + v)/√2, t = (u - v)/√2 thing if you like, and that will make at least part of the metric look more familiar, but there will be terms left over.
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
