What are the Kcat,Km,Kcat/Km enzymology values?
  • Thread starter cyentist
In summary, the kcat is the conversion rate when there is maximum substrate concentration that saturate the enzyme. The km is the conversion rate when there is half of the saturation concentration of the substrate. The kcat/km is the conversion rate when there is minimum substrate concentration. The specific activity is the maximal rate of the enzyme solution at saturating substrate concentration. v units are mM/sec and you can convert them into substrate moles per mg enzyme per minute by multiplying by the concentration in mM.
cyentist
Hello!
Can someone explain in simple terms the enzymology values of kcat, km and kcat/km?
From what I gathered all mean how many substrate molecules are converted by an enzyme molecule per unit of time, is this correct? (let's say the conversion rate)
The kcat is the conversion rate when there is maximum substrate concentration that saturate the enzyme.
the kcat/km is the conversion rate when there is minimum substrate concentration.
Are these accurate? What do we mean by minimum substrate concentration? How can I find the exact
conversion rate when I know the kcat/km and the substrate concentration of my solution?
I basically want to calculate the substrate conversion rate per mg of enzyme per minute for a specific concentration of the two substrates. What do I need to do that?
Also, there is specific activity as well, is this the same with kcat/km?
Thanks!
Chemistry news on Phys.org
cyentist said:
Hello!
This is a correct interpretation of kcat. You can think of kcat as the speed limit of the enzyme. This shows how fast the enzyme can act under optimal conditions (i.e. saturating substrate). kcat is also called the turnover number of the enzyme, since it represents the maximum number of substrate molecule the enyzme can react with per unit time.
This is incorrect. The units of Km are generally in terms of concentration (e.g. molar), so Km is not a rate. Km is usually interpreted to be a measure of the enzyme's affinity for the substrate. When the substrate concentration is greater than Km, the enzyme is easily able to grab onto the substrate, while when the substrate concentration is less than Km,
This is a good interpretation. kcat/Km is a useful measure of the efficiency of the enzyme because it considers both the maximal rate of the enzyme kcat, as well as the affinity of the enzyme for its substrate (Km). More efficient enzymes will have high kcat values (the enzyme can react with its substrates quickly) and low Km values (the enzyme can bind its substrate at very low concentrations), and both influence the kcat/Km value.
conversion rate when I know the kcat/km and the substrate concentration of my solution?[
The Michaelis-Menten equation will give you the initial rate of reaction between your enzyme and your substrate:
$$ v = \frac{k_{cat}[E][S]}{K_m+[S]}$$
You can also see how the interpretations of Km and kcat derive from the following equations. For example, when [S] >> Km, then Km +[S] ~ [S], so $$v = \frac{k_{cat}[E][S]}{[S]} = k_{cat}[E]$$
In other words, at saturating substrate concentration, the rate is the turnover rate of the enzyme times the number of enzymes you have.
In contrast, when [S] << Km, then Km+[S] ~ Km, so $$v = \frac{k_{cat}[E][S]}{K_m} = \frac{k_{cat}}{K_m}[E][S]$$
In other words, at low substrate concentration (i.e. substrate concentrations well below the Km), the rate is proportional to the amount of enzyme, the amount of substrate and kcat/Km.
The specific activity of the enzyme is similar to the kcat. The specific activity of the enyzme is Vmax/(mg enzyme), where Vmax is the maximal rate of the enzyme solution at saturating substrate concentration. Specific activity is a useful measurement when your enzyme preparation is not completely pure and there are other proteins present. Enzyme solutions that are more pure will have a higher specific activity. The kcat sets the theoretical maximum value of the specific activity.
Likes cyentist
Thanks!
What do I put for [E] if I have a porous material or surface where rhe enzyme is immobilised on and put in a solution of the substrate?
Also, what are the units of V and how do I convert them into substrate moles per mg enzyme per minute? It seems v units are mM/sec which is not convenient to convert into moles/sec
cyentist said:
Thanks!
In this case, I'd probably fit the kinetics data to this alternate form of the MM equation: $$v = \frac{V_{max}[S]}{K_m+[S]}$$
The units of v are generally units of concentration per time, though moles per time is also used. You can convert between mM/s to moles/s if you know the volume of your reaction. To calculate the specific activity of your immobilized enzyme, you would just calculate Vmax then divide by the mass of enzyme immobilized.
Likes cyentist
1. What do Kcat, Km, and Kcat/Km represent in enzymology?
Kcat, Km, and Kcat/Km are all kinetic parameters used to describe the efficiency of an enzyme. Kcat, also known as the turnover number, represents the number of substrate molecules converted to product per unit time by a single enzyme molecule. Km, the Michaelis constant, is the substrate concentration at which the rate of the reaction is half of its maximum. Kcat/Km is the catalytic efficiency, calculated by dividing Kcat by Km, and represents the rate of the reaction relative to the affinity of the enzyme for its substrate.
2. How are Kcat, Km, and Kcat/Km determined?
Kcat and Km are typically determined experimentally by measuring the initial rate of the reaction at different substrate concentrations. The data is then plotted and analyzed using the Michaelis-Menten equation. Kcat/Km can be calculated from these values or can be directly measured using more advanced techniques such as rapid kinetic methods.
3. What factors can affect Kcat, Km, and Kcat/Km values?
The values of Kcat, Km, and Kcat/Km can be influenced by various factors such as temperature, pH, enzyme concentration, and the presence of inhibitors or activators. Changes in the structure or conformation of the enzyme can also affect these values.
4. How do Kcat, Km, and Kcat/Km values differ between enzymes?
The values of these kinetic parameters can vary greatly between different enzymes. Kcat, for example, can range from less than 1 to over 10,000 reactions per second, depending on the enzyme. Km can also vary significantly, with some enzymes having high affinity for their substrates (low Km) while others have low affinity (high Km). Kcat/Km, on the other hand, is a more standardized measure of catalytic efficiency and can be used to compare the relative efficiency of different enzymes.
5. How do Kcat, Km, and Kcat/Km values impact enzyme activity?
Kcat, Km, and Kcat/Km are all important factors in determining the overall activity of an enzyme. A high Kcat value indicates a fast rate of reaction, while a low Km value indicates a high affinity for the substrate. A high Kcat/Km value indicates a highly efficient enzyme, while a low value may suggest that the enzyme is not well suited for its substrate. These values can also be used to compare the activity of different enzymes and to understand how changes in the enzyme or reaction conditions can affect its efficiency.
  • Chemistry
  • Biology and Chemistry Homework Help
26K
  • Biology and Medical
