What Are the Possible Dimensions of V Intersection W in R4?
The discussion revolves around the intersection of two 2-dimensional subspaces, V and W, within the context of R4. Participants explore the possible dimensions of the intersection V ∩ W and the implications of subspace properties in higher-dimensional spaces.
  • Some participants question the geometric interpretation of 2-dimensional subspaces and their intersections. Others suggest considering the implications of embedding dimensions on the intersection's properties. There are attempts to clarify misunderstandings regarding the nature of subspaces and their intersections.
The discussion is active, with various interpretations being explored. Some participants express confusion about the geometric aspects of subspaces, while others provide insights into the dimensional constraints of intersections in different dimensional spaces. Guidance has been offered regarding the necessity of including the zero vector in subspace intersections.
Participants note that the intersection of two subspaces must contain at least the zero vector, raising questions about the implications of this requirement in different dimensional contexts. There is also mention of the specific properties of linear transformations and their kernels in relation to the dimensions of the involved spaces.
helix999
If V and W are 2-dimensional subspaces of R4 , what are the possible dimensions of the subspace V intersection W?
I am new to subspaces, so I have no clue to this question. Help guys!
Options: (A) 1 only (B) 2 only (C) 0 and 1 only (D) 0, 1, and 2 only (E) 0, 1, 2, 3, and 4
You don't need to be concerned about the fact that V and W are subspaces, nor that they are embedded in a four-dimensional space.
V and W are two-dimensional, so you know what they look like geometrically, don't you? Now, what are all of the possibilities for the intersection of V and W?
you mean to say that V and W are 2x2 matrices and their intersection would also be a 2x2 matrix...so the required dimension is 2 only?
No, I didn't say that at all. What does any two-dimensional space look like geometrically?
I am sorry but i am not able to grasp the idea u r trying to put.
I think the possibility of dimensions would be 0,1, and 2.
Considering the real plane, what is the dimension of a single point? What is the dimension of a line?
it is single dimension
You do need to pay some attention to the dimension of the space they are embedded in. If they were embedded in three space a 0 dimensional intersection would be impossible.
I asked two questions. Your answer above is the answer to which question?
Yes, but I wanted the OP to focus more on the subspaces and not get tangled up in trying to imagine a 4-D space.
point is 0 dimension and line is single dimension
And a plane has 2 dimensions.
You also need to pay attention to the fact that they are subspaces. The planes (x, y, 0, 0) and (x, y, 0 , 1) have empty intersection. That is impossible for subspaces.
I got the answer of my question, really appreciate ur posts for making it clear to me. Thnx a bunch!
why is it impossible for subspaces?
How come a point can exist as an intersection of subspaces in 4 space but not in 3 space?
The 2-dimensional subspaces of R4, {(x, y, 0, 0)} and {0, 0, u, v}, have only the single point (0, 0, 0, 0) in common. Two 2- dimensional subspaces in R2 must have a least a 1-dimensional subspace in common.
If the intersection is the single point 0, then if you take union of a basis for one subspace with a basis of the other, the whole set must be linearly independent (otherwise you could construct another intersection point). In the case of two planes, that's 4 linearly independent vectors. Possible in 4 space, not in 3 space.
those were the new concepts for me...thnx
How do I proceed for such type of questions:
Let V be the real vector space of all real 2 x 3 matrices, and let W be the real vector space of all real 4 x 1
column vectors. If T is a linear transformation from V onto W, what is the dimension of the subspace
{v belongs to V:T(v)=0}?
In other words, "what is the dimension of the kernel of T" or "what is the nullity of T".
Is that really the entire question? There are many possible answers. For example, T(v)= 0 for all v is a linear transformation and it's kernel is all of V. Since V is a 6 dimensional space (Taking Vij to be the matrix with 1 at "ith row, jth column" and 0 everywhere else, for i= 1 to 2, j= 1 to 3 gives a basis), so that in this example, the dimension of the kernel would be 6.
On the other hand the linear transformation that maps
[tex]\left[\begin{array}{ccc} a & b & c \\d & e & f\end{array}\right]\right)[/tex] to [tex]\left[\begin{array}{c} a \\ 0 \\ 0 \\ 0\end{array}\right][/tex]
has nullity 5: dimension of the kernel is 5.
Perhaps the problem is "what is the smallest possible dimension of the kernel of T".
Since the largest the image of T can be is 4 dimensional, the dimension of "the real vector space of all real 4 x 1 column vectors", the smallest the kernel can be is 6- 4= 2.
That was the complete question and i guess i understood the explanation.
We solve the integrals like sqrt(1+x^4) dx (limit 0 to 1) by substituting x^2 as tan theta but how do we proceed for integrals like sqrt(1-x^4) dx (limit 0 to 1)?
Any subspace must contain the 0 vector so the intersection of two subspaces must contain at least the 0 vector. It is impossible for the intersection to be empty.
No, we do NOT substitute x^2 as tan theta. If we did then we would have 2 xdx= sec2 theta dtheta- and there is no "x" outside the square root to use with dx.
then how do we solve such integrals
There is only one answer because T is a linear transformation from V onto W.
Therefore the rank of T (or range of T) has to be 4.
Rank(T) + Nullity (T) = dimension of the domain of T (Where V supplies the domain with a dimension of 6).
And then you get Nullity (T) = 2 = dimension of Ker (T) => answer
  • · Replies 18 ·
